Latest: sparrowdclxvi
Overall: 17139
Online Now [106]:
Visitors: 105
Today: 38967
Total: 113566295
Forums › The Car › 206 Problems › AT lights in the dashboard
1st206
PostPosted: Fri Jul 01, 2011 6:15 am Up
Hi,
Would you guys know if the BSI also controls the AT indicator lights in the dashboard? Mine is always stuck in P even if I change the gears. The lights in the snow and sport mode does not work too. I already had a local electrician check the dash, multifunction switch and there were no problems found. They also did not find any error/fault code. Would the problem be the BSI unit?
Thanks and I hope you could help.
Cheers,\r\n1st206
