Latest: elelectricistadeMateo
Overall: 17127
Online Now [56]:
Visitors: 55
Today: 4758
Total: 100402986
Forums › The Car › 206 Problems › Heavy steering
Heavy steering
Go to page Previous  1, 2
LeeMaddern
PostPosted: Thu Jun 30, 2011 6:54 pm Up
my 180 has alot heavier steering then my old GLX. is that due to the speed adjustable steering ?
sorry about the hi-jack Wink
More photos on FaceBook - www.facebook.com/lmaddern1
PostPosted: Thu Jun 30, 2011 11:00 pm Up
looks like is low on fluid or the pump is on his last leg
broadblaster
PostPosted: Fri Jul 01, 2011 1:55 pm Up
my 180 is heavy compaied to other cars i have had but my little 1.4 hdi is same as any other car think its just a "thing" with the 180's but as said above it does make for good feedback
has the fluid ever been changed ??? you could try that and see if it helps
on a back road playing
PostPosted: Fri Jul 01, 2011 2:28 pm Up
Rob2859 wrote:
Nothing wrong with a bit of weight to the steering it gives more feel.
If only it was that simple. The 206 hardly has the most communicative steering.
PostPosted: Sat Jul 02, 2011 7:18 am Up
What He Said
Peugeot doesnt do communicative steering anymore, everything started to go wrong when they launched the 406.
I still think the 405 if it was still fitted with the original Peugeot shock's was one of the best handling cars of the last 20 / 30 years Cool
Some of the cornering speeds you could get on 3 wheels Thumbs Up
306 / ZX handle really well but im not keen on the passive rear wheel steering.
Page 2 of 2
