Online Now [346]:
Visitors: 345
Today: 162015
Total: 156876579
Forums › The Car › 206 Problems › Urgent help needed timing belt - inc photo
elcamino
PostPosted: Sat Jul 02, 2011 4:02 am Up
Hi.im changing my 1.4 petrol 8v timing belt but i dont know how to align crankshaft.there is a hole on camshaft for alignment but dont know where is the correct timing position for crankshaft.pls help ASAP.thanks a lot.
This is a photo of crankshaft pulley.as u see there are two marks one on the crankshaft pulley and another on the engine skin.i think they should be aligned for correct timing.but when i removed the cover they were not aligned.should i crank the shaft to align these two marks?green arrow is the original position i marked when i removed the cover..thanks for any help.
el camino. "Whether you think you can or you think you can't, you're right" Henry Ford.
meady
PostPosted: Sat Jul 02, 2011 4:04 am Up
Trade Rating: +45
Really really bd idea doing your timing belt when you don't no what your doing
TEAM - I HATE FACEBOOK Smile
2Oh!6
PostPosted: Sat Jul 02, 2011 4:25 am Up
General rule with cars really, if you don't know what you're doing at least research it first. DOH!!!
VTEC goes BWAAAAAAH! Wink
Abzynthe
PostPosted: Sat Jul 02, 2011 4:34 am Up
East Area Rep - Abzynthe
www.youtube.com/watch?v=VCe7r-Ke_wQ
Just googled quickly, and this came up. I havent watched it as its blocked at work.
