Online Now [508]:
Visitors: 507
Today: 124072
Total: 154933067
Forums › The Car › 206 Problems › Running on 2 Cylinders
Xlinephil
PostPosted: Mon Jul 04, 2011 3:35 am Up
Hi Guys
I pretty sure my partners 206 is only running on 2 cylinders at the moment, I perform the test where you allow water to evaporate on a freshly warmed engine, cylinders 1 & 4 seemed very cold. The car has already had a new coil pack, and all the information on the web seems to suggest injector No. 4 is the problem one. Are the injectors wired in series? How do I go about removing the injector and replacing it with a second hand one? Do I simply remove the fuel rail and pull the injector using my hands or do I need to de-pressurize the fuel system first?
Any advice greatly appreciated!
2003 1.4 206
PostPosted: Mon Jul 04, 2011 3:37 am Up
Have you changed the spark plugs? It's fairly common for coil packs to fail on 206s.
Xlinephil
PostPosted: Mon Jul 04, 2011 3:43 am Up
The coil pack has been changed yes, not the spark plugs though but I inspected and gapped them when I changed it and all seemed acceptable.
2003 1.4 206
PostPosted: Mon Jul 04, 2011 3:44 am Up
Oh sorry, I missed that you had already changed the coil pack. Still on my first coffee.
Injector wise, unbolt the fuel rail & they pull out. Just a case of pushing them back in.
Xlinephil
PostPosted: Mon Jul 04, 2011 3:46 am Up
thanks, I was hoping it was that simple. Do you think its worth buying two injectors as both 1 & 4 cylinders are failing?
2003 1.4 206
Not NGK spark plugs I hope Wink
These are a NO NO for a 206 Wink
PostPosted: Mon Jul 04, 2011 4:00 am Up
This really needs scanning for fault codes.
The engine ecu is smart enough to shut of the fuel injector to a cylinder if the spark plug / coil pack is misfiring on that pot
Cylinder 1 is the gearbox end, PSA Peugeot / Citroen like to do things different Laughing
PugJH
PostPosted: Mon Jul 04, 2011 4:29 am Up
Reading the Original Post it looks like he has the problem with the washer jets leaking down onto 1 and 4, like the problem you spoke about to me.
I am changing my injector either tonight or this coming friday, so maybe i can do a how to and save the world.
Also how bad must her car be running, we cut mine down to 2 and it sounded rough to say the least, hope she isnt driving it still...
Just to make it clear whats said above, cylinder 4 = left as you look from the front, ie the hardest one to get ya hand round due to the engine mount *on a 1.1 anyway*
WIP: Black 1.6 16v XSi
Beauté Noire
PostPosted: Mon Jul 04, 2011 5:13 am Up
It ran like a bag of s**te on just 2 pots Laughing
LeeMaddern
PostPosted: Mon Jul 04, 2011 5:48 am Up
i had this problem a week ago, mine was only one cylinder though. this is what mine sounded like
- www.youtube.com/watch?v=ISlCJVWTgpA
mine was a faulty coilpack.
they also mentioned something about the intake manifold can cause problems which seems like a faulty coilpack.
More photos on FaceBook - www.facebook.com/lmaddern1
Xlinephil
She is still driving, she has no choice as she needs to get around in her job! Thats why I need to fix it asap lol.
Just rang up a scrappy and they say that there are different ones so how do I determine which to order?
2003 1.4 206
LeeMaddern
PostPosted: Mon Jul 04, 2011 5:54 am Up
coil pack ?
Xlinephil
PostPosted: Mon Jul 04, 2011 5:58 am Up
LeeMaddern wrote:
coil pack ?
had a new one fitted, no difference
2003 1.4 206
wurlyvalve
PostPosted: Tue Jul 05, 2011 1:34 am Up
Have you got good compression on all the cylinders?
555 P Diddy
sri16v
PostPosted: Tue Jul 05, 2011 8:05 am Up
second this advice, do a compression test, can you give a lot of clues as to whats going on.
If you have a fault code reader that can delete codes,remove the injectors so you can see if they are working and also for spray pattern
2004 GTi 180
