Online Now [354]:
Visitors: 352
Members: 1
Today: 80173
Total: 156073256
Forums › The Car › 206 Talk › speedo swap keeping the mileage
Forum Index › 206 Talk
kieron
PostPosted: Mon Jul 04, 2011 6:35 am Up
Right i drove the car yesterday and my speedo was jumping all over the place and now has stoped all togeather but flickers now and then
the mile reset still works fine so i know its not the speedo drive sensor at fault so must be the clock itself
when i find a GTI clock will i just be able to replace the speedo and not the rest so i can keep my mileage? as im dont want to loose my mileage on the car as its quite low for its age(53k)
cheers kieron
Account suspended
L5_UKS
PostPosted: Mon Jul 04, 2011 6:57 am Up
Im pretty sure your milage is saved in your ECU and not on the speedo itself?
PostPosted: Mon Jul 04, 2011 6:58 am Up
It always shows the higher number.
Swardy
PostPosted: Mon Jul 04, 2011 7:33 am Up
what year is your gti?
later phase 2 models save the mileage in the dial and in the dash and will always display the higher of the two. so if yours is a later one you'd need to find a clock that has a lower mileage on than yours.
If it's an earlier one, phase 1, it'll display whatever the dial has saved as it is not stored anywhere else.
I know this because I had to replace my dial display. Mine is the earlier phase 1.
206 gti (138), Superchips remap, K&N panel filter, Scorpion cat back
kieron
PostPosted: Mon Jul 04, 2011 7:37 am Up
its a 2001 gti, i was hoping to just was over the speedo and keep my clocks and and motherboad so hoping the mileage will stay the same.
Account suspended
Swardy
PostPosted: Mon Jul 04, 2011 7:57 am Up
Is it a phase one?
It's so easy to swap the whole dial cluster mate. It's just one torx screw and clip in. it'd be harder work just swapping the one dial, if that's even possible.
I swapped mine for a whole cluster then got the mileage corrected.
PostPosted: Mon Jul 04, 2011 11:08 am Up
Non-plexed = mileage shows whats ever in the cluster
Plexed = shows which ever is the highest in the ECU and cluster
Relatively easy to change if you have a eeprom programmer
PostPosted: Tue Jul 05, 2011 1:00 am Up
Your confusing phase 1 & 2 with non plexed & multiplexed
Multiplex was fitted 2 years before phase 2 car's came out.
kieron
PostPosted: Tue Jul 05, 2011 1:08 am Up
Its non plexed ... so its going to cost a few quid to get the mileage corrected then
Account suspended
Swardy
PostPosted: Tue Jul 05, 2011 1:41 am Up
Yeah, i knew that but was just being a bit lazy to be honest. Sorry, my bad.
Swardy
PostPosted: Tue Jul 05, 2011 1:43 am Up
Look in te back of your local autotrader. There'll be people that do digital mileage correction.
PostPosted: Tue Jul 05, 2011 10:53 am Up
You should need to read the eeprom on non-plexed. You could use a tachopro on plexed
