Online Now [559]:
Visitors: 557
Members: 1
Today: 109409
Total: 156824455
Forums › The Car › 206 Talk › ball joint - track rod end
Forum Index › 206 Talk
qwert
PostPosted: Tue Jul 05, 2011 11:11 am Up
....are these the same thing?
brum brum
Andy180
PostPosted: Tue Jul 05, 2011 11:12 am Up
nope
GTI 180
Seb
PostPosted: Tue Jul 05, 2011 11:14 am Up
Staff - Seb
No, ball joints are mostly on wishbone ends, a track rod end is attached to the hub and leads to the track arm for the steering, or the chassis or a mounting point on the rear (but not on a 206 as it has a fixed axle).
qwert
PostPosted: Tue Jul 05, 2011 11:15 am Up
its just on service box, the balljoint kit looks like a nut and the track rod end
brum brum
PostPosted: Tue Jul 05, 2011 11:30 am Up
This??
PostPosted: Tue Jul 05, 2011 11:42 am Up
Also sayings in the Haynes "track rod balljoint" and there for sale here as well on eBay - www.ebay.co.uk/itm/Peu..._656wt_905
HFStuart
PostPosted: Tue Jul 05, 2011 1:09 pm Up
Ball joint is the name for a type of sperical bearing where a ball sits in a cup of some sort. They are used to tranmsit forces between two parts where the angle between them varies in more than one plane.
So they are both ball joints but track rod end is used pretty much exclusively for the joints on the ends of the steering arms.
On servive box part 5 is the track rod kit that includeds the track rod end and the locking nut. The nut that joints the track rod end to the hub ( 70 )is separate (Typical tight Peugeot)
