Latest: heikkisj
Overall: 17126
Online Now [46]:
Visitors: 45
Today: 20464
Total: 100282785
Forums › The Car › 206 Problems › fan only comes in when temp gauge shots to the red
sw20-3sgte
PostPosted: Wed Jul 06, 2011 5:15 am Up
Hey people im new to this forum and writting this on behalf of a friend that never uses the internet ..
he has a X reg 206 (1.1 litre).. the problem is the cars temp sits in the middle as it should no fan kicking in or anything..
then from half way it shoots up to the red bit along with the "stop" sign and the fan kicks in and brings it back to normal, so as the gauge shows normal the fan goes off.. then it repeats and repeats
many thanks in advance antony
if in doubt flat out
Ali_H
PostPosted: Wed Jul 06, 2011 5:17 am Up
Not really sure I know what you're asking tbh.
Sounds normal, when it goes to red the fan will cut in to stop it overheating.
kurtis wrote:
PostPosted: Wed Jul 06, 2011 5:22 am Up
low speed fan relay or resistor or dodgy wires more than likely
your low fan speed doesnt seem to be working reading that
sw20-3sgte
PostPosted: Wed Jul 06, 2011 5:26 am Up
sorry buddy i wasnt clear, it sghouldnt be going to red surely the fant will kick in before it goes that high
sw20-3sgte
PostPosted: Wed Jul 06, 2011 5:27 am Up
which relay is that then ?? is it 1 of the 2 that are right next to the fan ??
and were is the resistor Embarassed
thanks for your help
PostPosted: Wed Jul 06, 2011 5:28 am Up
yes they are next to the fan indeed. im pretty sure its the top one.
resistor is underneath behind a plastic cover.
sw20-3sgte
PostPosted: Wed Jul 06, 2011 5:29 am Up
ill check that out and report back
www.petercoopercarrepa..._fan_w.htm
sw20-3sgte
PostPosted: Wed Jul 06, 2011 5:34 am Up
DJ- wrote:
http://www.petercoopercarrepairs.co.uk/peugeot_206_engine_cooling_fan_w.htm
Low speed cooling fan not working and water temp getting too hot and temp gauge reading about 90 degrees and then going rapidly in red / hot area and dash flashing “STOP”. Cooling fan then cuts in at fast speed. Fault was corroded connector at low speed fan resistor.
that is what is happening illl try it out thanks dude
Heffalump
PostPosted: Wed Jul 06, 2011 5:49 am Up
Result, just realised this is happening with mine.
Heffalump
sw20-3sgte
PostPosted: Wed Jul 06, 2011 8:54 am Up
waiting for the item to get delivered i took the old 1 off the car and it looks in real bad condition hopefully i have found my problem
DREWDEN
PostPosted: Wed Jul 06, 2011 9:19 am Up
Am i right in stating that the cooling fan resister, are only on models with air con
206 2ltr Hdi glx 53 plate
sw20-3sgte
PostPosted: Thu Jul 07, 2011 3:09 am Up
not sure my mates model has aircon.. dont really know my way around a 206 buddy..
still waiting for the part Sad
PostPosted: Thu Jul 07, 2011 3:11 am Up
what are you replacing? which part you waiting for?
sw20-3sgte
PostPosted: Thu Jul 07, 2011 3:15 am Up
the "low speed fan resistor" it has bad corrosion , i have checked the wiring and thats all clean and tidy
