Latest: Worthy967
Overall: 17143
Online Now [573]:
Visitors: 572
Today: 118292
Total: 114694439
Forums › The Car › 206 Problems › Car not putting the power down (catching up to revs)
Mod4hire
PostPosted: Fri Jul 08, 2011 11:27 am Up
Hi all,
Car (1.6 16v Xsi 2001)
For this kind of a problem I thought it was the clutch, so last weekend I had the whole thing replaced with the OEM version. Seemed fine driving it back etc... But gave it its first real drive last night. Now the mechanic that did the job is a family friend, been a mechanic for nearly 30 years and he said the clutch he removed was pretty knackered, which doesn't suprise me as the car had a pretty neglectfull 100,000k life before I owned it the last 5000k. Since then I've had a full cam belt kit on, fully serviced it, sparks super 4's of course, front and rear brakes needed replacing, same goes with the front discs. It has needed a lot of work since I've owned it, but I love the car and don't mind the odd bit going here and there, but now I'm stuck with what could be wrong with it now. The revs far exceed what the car should be putting down, as an example when I tested for the problem yesterday, I took the car in 2nd up to 5000 revs and it was struggling to catch up to 40 on the clock, eventually the car caught up and the car was matching the revs.
Can anyone advise me here please?
Thanks in advance Smile
PostPosted: Fri Jul 08, 2011 11:42 am Up
oil on the clutch?
MrZiggerz
PostPosted: Fri Jul 08, 2011 11:45 am Up
Slipping clutch. Like Seabrook said.
Mod4hire
PostPosted: Fri Jul 08, 2011 11:49 am Up
Its just had a new one a week ago, how can it be slipping?
macj
PostPosted: Fri Jul 08, 2011 11:50 am Up
What was the flywheel face like.
Had one in with the friction/drive plate in the wrong way round
MrZiggerz
PostPosted: Fri Jul 08, 2011 11:51 am Up
Ask your family friend who did it, cause that's what it sounds like to me.
PostPosted: Fri Jul 08, 2011 11:53 am Up
Is the clutch cable adusted correctly?
Mod4hire
PostPosted: Fri Jul 08, 2011 12:05 pm Up
Don't think the cable would be an issue, its a hydrolic clutch? Not sure on the fly wheel, I've left a message with him, when he gets back to me I shall enquire the above Smile
mjsroofing
PostPosted: Fri Jul 08, 2011 1:02 pm Up
clutch problem somewhere,
Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k.
-Dave-
PostPosted: Fri Jul 08, 2011 1:25 pm Up
Trade Rating: +36
I think that had been established Laughing
Ex 206 Owner.
PostPosted: Fri Jul 08, 2011 1:50 pm Up
DOH!!!
Mattie-RS
PostPosted: Fri Jul 08, 2011 2:47 pm Up
Is it a clutch problem?
Mod4hire
PostPosted: Sun Aug 14, 2011 6:14 am Up
Been a while since I posted this, but the problem has only just been solved. A full clutch kit was fitted all was well, but the slave cylinder went shortly after the new kit was fitted causing slip, which in turn burnt the clutch a little. But because I know the guy he straight swapped it (with a story) for a valeo one and fitted a new slave cylinder along side the valeo, all is well now the cars driving great Smile
