Online Now [788]:
Visitors: 788
Today: 27330
Total: 154238453
Forums › The Car › 206 Problems › CV Joint
CV Joint
rhysgerrard
PostPosted: Sun Jul 10, 2011 6:24 am Up
Hi guys,
All of a sudden my cv joint on the left hand front wheel has started clicking when I turn. For instance when I'm turning round a corner it will click until I stop turning.
Can I plea have some advice on either,
1. How to repair it and if it's a common problem.
2. How much it is likely to cost?
Cheers again
Rhys
orangeGTI
PostPosted: Sun Jul 10, 2011 7:49 am Up
just had our cv joint replaced co about £40.
For vinyl sticker please look at www.206info.co.uk/Foru...30851.html
Or PM me.
Rincewind
PostPosted: Thu Jul 21, 2011 10:11 am Up
If you can do it yourself then it's cheap, i did my gf's 206 and it was £19 from a company called J&R in birmingham. They have a shop on ebay selling Cv joint kits. Smile
206 XSI 1.6
Rincewind
PostPosted: Sun Jul 24, 2011 3:47 am Up
That companys id on ebay is j_r2006 Smile Used them loads of times and they are spot on, £23 delivered next day for a CV joint complete with gaitor, metal bands and grease and new hub nut. Never had any problems with them Very Happy Very Happy Only takes 45 minutes to change it too.
206 XSI 1.6
snowonfire
PostPosted: Wed Jul 27, 2011 2:14 pm Up
Yeah peice of pie to do... if its just a quick fix your after I'd use the split cv joint (the one with glue and cable tie)
The only cost about £15-£20
cartoonhead
PostPosted: Wed Jul 27, 2011 3:44 pm Up
once the shaft is out undo the clips holding the CV boot ( rubber thing on the back of the CV ) and if you clean out the worst of the grease you will see a circlip which needs to be opened up and then tapp the CV off.
put the new CV boot on the shaft and pack new CV with grease and put it on the shaft making sure the circlip has locked into place.
