Online Now [454]:
Visitors: 453
Today: 15679
Total: 156894128
Forums › The Car › 206 Problems › fan test
fan test
no_offences
PostPosted: Mon Jul 11, 2011 2:59 pm Up
my fan seems to have gone, ive checked all fuses and all the swithes are connected, it wont come on and is causing the car to overheat, i have no warning lights but im unsure if there would be if it did go, can anyone shed some light on it?
and are all 206 fans the same if it is broke? it looks the exact same size as the one in my old 1.4 but im not 100%
Signature removed due to size
PostPosted: Mon Jul 11, 2011 3:06 pm Up
with A/C or without A/C use different fan.
not sure if plex matter too.
engine size is irrelvant in this case.
PostPosted: Mon Jul 11, 2011 3:07 pm Up
Checked that the two relays haven't corroded?
no_offences
PostPosted: Mon Jul 11, 2011 3:26 pm Up
i have ac and its gt so its pre plex, and where are the 2 relays?
DREWDEN
PostPosted: Mon Jul 11, 2011 4:27 pm Up
Just wondering the fuse for the fan on my car, can't be seen until you pull the whole fuse box out of its plastic housing.(ENGINE COMPARTMENT)
there's 6 very large main fuses fuse no1 being the fan 20amp.
is yours like mine a small rectangular fuse box (18 tiny fuses) with a clip either side of the cover
206 2ltr Hdi glx 53 plate
no_offences
PostPosted: Mon Jul 11, 2011 5:03 pm Up
i checked the lot, i changed 2 splatter ones neither made any difference, im going to check for corroded relays
no_offences
PostPosted: Tue Jul 12, 2011 5:54 pm Up
do i have to strip the bumper off and fan off to check the relays
DREWDEN
PostPosted: Tue Jul 12, 2011 6:41 pm Up
onNo neither. First take the front grill off, (4 plastic studs with centre pins) Then take off the front trim panel (logo on) 2 plastic clips each side,
hold it to the wings.
To the left of the fan looking from the front, you will see a plastic cover for the relays,(3 plastic studs with centre pins)
A bit tight with your hands but manageable.
PostPosted: Tue Jul 12, 2011 11:46 pm Up
It's easier to inspect the wiring with the bumper off but you can get away without removing it.
no_offences
PostPosted: Sun Jul 17, 2011 5:07 pm Up
thanks people, the rad and fan are splatted ordered some new parts, the relays were f****d the fan housing is wonky, and the rad has a crack on the pipe and the bottom, new bits ordered lol
