Latest: DanDan17
Overall: 17128
Online Now [65]:
Visitors: 64
Today: 5422
Total: 100433148
Forums › The Car › 206 Problems › coolant hose
coolant hose
PostPosted: Tue Jul 12, 2011 4:36 pm Up
are those reusable clamp called clic clamp?
anyway plan to renew the coolant this weekend. and some of the coolant hose clamp are quite rusty so might get some new clamp too.
was wondering can i replace them with stainless steel jubilee clamp?
PostPosted: Tue Jul 12, 2011 4:49 pm Up
Aren't clic for plastic piping?
They're jubilee clips on mine Confused
PostPosted: Tue Jul 12, 2011 4:55 pm Up
i am pretty sure mine was clic clip
<--something similar to this.
and i remember macj's gti use the same clip too.
it is just i can't find anything stainless steel clic clip.
might check it again tomorrow... Confused
Antknee
PostPosted: Tue Jul 12, 2011 4:56 pm Up
I have jubilees on mine too
PostPosted: Tue Jul 12, 2011 4:58 pm Up
maybe we are talk about different part?
i mean the clip to sercure the coolant hose to the radiator
PostPosted: Tue Jul 12, 2011 5:01 pm Up
I've got jubilee on one hose and one of them on the other
PostPosted: Tue Jul 12, 2011 5:04 pm Up
ok, i just check on service box Laughing
apparently pug use jubilee only on the coolant expanion tank end. for the rest of the sysyem it use clic clamp.
any through why?
or where can i get some stainless steel clic clamp?
PostPosted: Tue Jul 12, 2011 5:08 pm Up
Wonder if its because they'll expand and contract with the heat from the pipes?
These sell them, dunno if they have the right size tho Confused www.auto-connect.co.uk..._3303.html
PostPosted: Tue Jul 12, 2011 5:12 pm Up
thanks lee, i will have a look tomorrow Smile
PostPosted: Tue Jul 12, 2011 11:50 pm Up
My cars uses the clips in the this lot on everything except the bottom reservoir hose.
PostPosted: Wed Jul 13, 2011 11:05 am Up
new clamp and bolts are so lovely.
