Online Now [357]:
Visitors: 356
Today: 54118
Total: 154618583
Forums › The Car › 206 Talk › painting rocker cover
Forum Index › 206 Talk
austin316
PostPosted: Wed Jul 13, 2011 3:41 am Up
Hi all, cant see a 'How to' but what is the best way to paint my rocker cover? should i use the high temp paint, or would hammerite paint be ok? thanks
5 door
1.1 8v
04 reg
JE_180
PostPosted: Wed Jul 13, 2011 3:44 am Up
I used regular spray paint, seems to be fine so far lol
austin316
PostPosted: Wed Jul 13, 2011 3:45 am Up
did u primer and lacquer it as well?
5 door
1.1 8v
04 reg
JE_180
PostPosted: Wed Jul 13, 2011 3:47 am Up
ofcourse, 3 coats of plastic primer, about 3 of paint and the same in lacquer.
austin316
oki, thanks mate
5 door
1.1 8v
04 reg
Kersh
hammerite is high temp paint.. they just dont really market it as that. why do you think most people use it for their brake callipers Smile
Member number: 36
JE_180
PostPosted: Wed Jul 13, 2011 3:50 am Up
Because regular caliper paint is s**t lol
JE_180
PostPosted: Wed Jul 13, 2011 3:52 am Up
austin316 wrote:
oki, thanks mate
No problem, mines a 180 so it's a plastic cover, hence the plastic primer (after lightly sanding it down with 800 and then1200 grit wet n dry), obviously use the apropriate primer for whatever surface you're painting though.
iainlovatt
PostPosted: Wed Jul 13, 2011 4:03 am Up
are you painting the plastic part on the engine or the metal rocker cover?
(My Garage)
iainlovatt
PostPosted: Wed Jul 13, 2011 4:04 am Up
clicky
(My Garage)
Didz
PostPosted: Wed Jul 13, 2011 10:50 am Up
yeah hammerite would do it, but the last one i did i used VHT as the primer, 2-3 coats of that ad the colour and then the laquer. Worked great. Was still looking bright and bubble/blemish free after 2 years lol
Life's for living....
PostPosted: Wed Jul 13, 2011 12:29 pm Up
VHT paint is quality, just a bit more pricey.
