Online Now [691]:
Visitors: 690
Members: 1
Today: 107391
Total: 152508671
Forums › The Car › 206 Problems › water in passanger footwell
ian89
PostPosted: Sun Jul 17, 2011 5:43 pm Up
the car was parked up all yesterday (saturday) and it wasnt raining the day before when i took it out but got isn't it today(sunday) and there was a puddle in the middle of the passanger footwell the surrounding area of the carpet isnt wet checked the vents the doors and seals no signs of leaks checked the roof and window all dry. sat in it whilst it pourd down and no signs of leaks.
i know sounds crazy but any ideas
Antknee
PostPosted: Sun Jul 17, 2011 5:48 pm Up
Possibly the heater matrix
Antknee
PostPosted: Sun Jul 17, 2011 5:50 pm Up
And check the holes in the bottom of the door isnt blocked
Sprayed up from the front wheel into the floor pan seam?
NICKST
PostPosted: Mon Jul 18, 2011 1:00 am Up
What He Said
Abzynthe
PostPosted: Mon Jul 18, 2011 1:17 am Up
East Area Rep - Abzynthe
I had this after leaving my car for a while. Cant really diagnose it as the problem went away after I changed the engine :S
But most likely are the above suggestions. Door seals or heater matrix.
meady
PostPosted: Mon Jul 18, 2011 3:15 am Up
Trade Rating: +45
Am i right in thinking if the foam sheet behind the door card is damaged tht can let water in?
TEAM - I HATE FACEBOOK Smile
Antknee
PostPosted: Mon Jul 18, 2011 7:49 am Up
Yessum
Pearcy
PostPosted: Mon Jul 18, 2011 1:49 pm Up
I had the same today apart from it was in the drivers footwell... Tried to find it but couldn't but i'm not sure if the sheeting behind the doorcard has been removed or not.
continentalgt
PostPosted: Mon Jul 18, 2011 2:01 pm Up
Yes it's there to keep the water that inevitably bypasses the window seals inside the door where it should then drain out of the bottom of the door.
I had this problem on a rear and drivers door and found the foam membrane was damaged and had become detached around the edges. I repaired it with builders silicone and it completely cured the problem.
With the door open wide and with the window closed pour water as fast as a watering can will allow along the outer window seal at the base of the window, if the membrane is at fault you should see water leaking on the inside of the door from behind the door card. It will also pour out from the bottom of the door but thats OK.
PostPosted: Mon Jul 18, 2011 2:17 pm Up
Sounds silly but Smell the water, if it's heater matrix you will smell the anti freeze, how I worked mine out anyway.
My mate went as far as tasting it Confused Lol
oldskoolz
PostPosted: Mon Jul 18, 2011 2:31 pm Up
I've found water in both my footwells before (on separate occasions). Couldn't find the source of the leak but the sills had slight puddles in them as well, so guessing it was from the door somehow
Black 206 Gti. Soon to be 2.2
ian89
PostPosted: Tue Jul 19, 2011 10:23 am Up
had the carpet up and no holes in the actual footwell, checked the door seals where tight and also checked the it is clean water and doesnt taste of anti-freeze but keep up the suggestions please.
its weeing it down outside so i'll see if i get another puddle
EnzoGirl
PostPosted: Tue Jul 19, 2011 3:39 pm Up
my passenger footwell filled up when the heater matrix went
Live Slow...Drive Fast.....
