Online Now [394]:
Visitors: 393
Today: 135264
Total: 154691144
Forums › The Car › 206 Talk › raising up the car
raising up the car
Forum Index › 206 Talk
bisphenol-a
PostPosted: Sat Jul 16, 2011 1:20 pm Up
hey fellas
i have 1 x trolley jack and 2 x car axle stands and tons of bricks in the backyard. im looking to remove the wheels 2 at a time and giving the calipers a nice coat of paint over Very Happy
am i missing out any essential items that could aid in safely raising the car? i was reading some threads and i saw that a piece of wooden block was sometimes stuffed between the jack and the car. well, the real question is where does the trolley jack go to lift up the front and the rear and where do the car axle stands sit when holding the front or rear up. my main concern is ensuring things are done right. dont wish to hurt myself or the car :/
if there were pictures that would be most helpful!
thanks for reading.
PostPosted: Sat Jul 16, 2011 1:25 pm Up
If you look under the car there are two beams at either side of the car running from the front end to midway of the rear. Put the jack in the middle, and it will lift the side up easily. Then put the axle stands on either that beam or jacking point at the front. And a axle stand on the jacking point or center rear where the spare wheel is
bisphenol-a
PostPosted: Sun Jul 17, 2011 11:20 pm Up
where does the trolley jack go if i want to jack up the front end once to put the 2 axle stands?
JE_180
PostPosted: Mon Jul 18, 2011 12:56 am Up
I jack mine up on the sills lol :/
bisphenol-a
PostPosted: Mon Jul 18, 2011 10:15 am Up
that shouldnt be happening i thought
PostPosted: Mon Jul 18, 2011 10:26 am Up
jack point is on the sill
Rob2859
PostPosted: Tue Jul 19, 2011 9:15 am Up
I jack mine up on the sill as it doesn't go under anyway (So how i am going to manage after today when its been lowered I don't know) and then I put a stand under the subframe for the front and under the shock for the rear.
