Latest: Worthy967
Overall: 17143
Online Now [586]:
Visitors: 585
Today: 100025
Total: 115585019
Forums › The Car › 206 Problems › Central locking problem
drew
PostPosted: Mon Jul 18, 2011 6:21 am Up
my remote central locking's stopped working, the red light just flashes on my key when trying but no response from the car. Could this just be the fuse or the key battery gone flat?
AX-Rated
PostPosted: Mon Jul 18, 2011 6:24 am Up
Try your central locking on the key on the door first, and report back. That would answer alo't of questions if they work on the door.
They're has been previous problems with pug fobs playing up.
I had problems on a 106, that despite lighting up and with a fresh battery, refused to operate the locking.
Turned out to be some dry joints on the board inside the keyfob.
But I'm sure it affects infra red keyfobs and not the FM ones.
Which type do you have?
Black 03 GTi
drew
PostPosted: Mon Jul 18, 2011 6:27 am Up
It works if I just unlock it using the door just not remotely.
Yeah I tried searching it as I've seen a lot of central locking problems but none of them seemed to help with this.
I'm not certain, how can you tell which type it is?
Black 1.4 lx, you can only tell when it's moving....
AX-Rated
PostPosted: Mon Jul 18, 2011 6:40 am Up
If the fob is all black with two buttons then its the FM type.
If its got 1 button and a infra red type LED sticking out the top near where the key comes out of the fob then its the infra red type.
Black 03 GTi
drew
PostPosted: Mon Jul 18, 2011 6:55 am Up
it's just got one button and the red light is next to the button?
davieboy86
PostPosted: Mon Jul 18, 2011 7:47 am Up
Mine is intermittent at the moment, along with the bouncing lock s.
AX-Rated
PostPosted: Mon Jul 18, 2011 7:48 am Up
Drew, yours sounds like a infra red type.
Visit a pug dealer, they should have a infra red keyfob tester, ask them if there's a signal coming from it.
Black 03 GTi
drew
PostPosted: Mon Jul 18, 2011 10:02 am Up
It's working again now :S
I didn't even do anything to it, odd.
PostPosted: Mon Jul 18, 2011 10:22 am Up
All 206 fobs are RF (radio), not Infra-Red.
Rincewind
PostPosted: Thu Jul 21, 2011 9:59 am Up
Not relevant on this thread but handy tip for the future. All infra red remotes can be tested with the camera on your phone. Even your tv or dvd remote Laughing , turn your camera on and point it at the tiny glass bulb on the remote and press any button on the remote and look at your phone screen. If it's working you'll see flashing on your phone screen. Smile
206 XSI 1.6
