Latest: SA01
Overall: 17138
Online Now [279]:
Visitors: 277
Members: 1
Today: 11319
Total: 112235811
Forums › The Car › 206 Problems › Rear hub nut - tightening torque
PostPosted: Fri Jul 22, 2011 1:49 am Up
Got to take the rear drums off today (1.4 2003 model) as brake pedal went to the floor last night and I suspect the shoes have disintegrated. The brake fluid level is fine, but handbrake travels all the way up.
I haven't got round to buying a Haynes yet, (can't even get to Halfords to buy one) but I need to know if they recommend a tightening torque for the rear hub nut. I don't fancy swinging on the nut and crushing the bearing and the wheel falling off or undertightening and the wheel wobbling about.
Any help will be appreciated. Thanks
PostPosted: Fri Jul 22, 2011 2:09 am Up
200 Nm
PostPosted: Fri Jul 22, 2011 2:14 am Up
Thanks Seabook. Just about to get the wheels off.
PostPosted: Fri Jul 22, 2011 2:17 am Up
good luck, taking the old nut of is a bit of hard work Laughing
PostPosted: Fri Jul 22, 2011 8:31 am Up
All sorted. Got the nuts off a piece of cake. I've got a few different size punches so wasn't a problem.
The friction material had come unbonded from the shoe.
Hardest part was getting a taxi so I could get to the motor factors for the shoes.
The auto adjuster had siezed on the nearside so gave that a good clean too.
I had noticed that the handbrake was sticking on one side when left to stand overnight. Then it cured itself.
The other day some dozy mare in a chelsea tractor decided to pull out right in front of me and I locked one of the rears up, so that might have been where the damage to the shoe came from.
