Latest: S2cgm
Overall: 17178
Online Now [78]:
Visitors: 76
Bots: 2
Today: 110029
Total: 136321884
Forums › The Car › 206 Problems › P0121 - Throttle Position Sensor/Switch A Circuit Range/Perf
sahdra
PostPosted: Thu Jul 21, 2011 12:12 pm Up
Hi Guys!
I have had my GTi 180 coming on 2 years and have had no problems whatsoever, and the other day i got the dreaded 'ANTIPOLLUTION FAULT' and the engine management light came on while driving along.
I initially did a search on here and a few people have said unplug the VVt sensor near the engine oil cap ...it worked!! Then the problem came back within hours, i then tried cleaning the sensor too, it was clean but did it anyway ...still no luck Sad
Now i get about 15 minutes out of the car before the misfiring starts and rough sounding engine with little power.
...anyway, so i took a reading of the fault codes. This is what i got:
STORED TROUBLE CODES
P0351 - Ignition Coil A Primary/Secondary Circuit Malfunction
P1153 - Unknown Diagnostic Trouble Code
P1158 - Unknown Diagnostic Trouble Code
P0123 - Throttle Position Sensor/Switch A Circut High Input
P1161 - Unknown Diagnostic Trouble Code
P0121 - Throttle Position Sensor/Switch A Circut Range/Performance Problem
P0075 - Intake Valve Control Solenoid Curcuit
PENDING TROUBLE CODES
I then assumed some of these may be old so cleared everything and then started the car to see what would come up and i got the following under both Stored and Pending trouble codes...
P1160 - Unknown Diagnostic Trouble Code
I just wanted to know if anyone could help me read this data and fix my baby!!
Thanks in advance
Black GTi 180/SP pack
sahdra
PostPosted: Fri Jul 22, 2011 1:00 pm Up
Just an update...
I changed the spark plugs to bosch super's and stuck a new coil pack in and still no luck.
Error codes i'm seeing are:
P1160 - intake manifold temp
...any ideas anyone?
PostPosted: Fri Jul 22, 2011 1:53 pm Up
Intake manifold pressure sensor with integrated air temp sensor....looks like this....
Schumi
PostPosted: Fri Jul 22, 2011 1:58 pm Up
To much error. Did you change your car battery ?
2005 206 RC RED
PostPosted: Fri Jul 22, 2011 2:00 pm Up
Could have been old fault codes though that weren't cleared. If he cleared them and only the intake mani code came back....
sahdra
PostPosted: Fri Jul 22, 2011 3:03 pm Up
The first lot of errors was mainly because things like..
P0075 - Intake Valve Control Solenoid Curcuit came up when i unplugged the VVt plug. My current issues seem to be those two above.
I even bought a coilpack for £140 so have that going if anyones interested lol
sahdra
PostPosted: Fri Jul 22, 2011 3:05 pm Up
Mate you are a legend!! just taken it out for a splash of Brake Clean. guessing these are only a few quid so may go pick up another if i see an improvement Smile
I did notice some oil down the manifold when i took the throttle body off ...anything to be worried about?
sahdra
PostPosted: Sat Jul 23, 2011 6:24 am Up
okay.. so i changed the sensor and now all fault codes have gone but the car doesnt want to stay alive. when i start it it just goes to keep wanting to cut out. with some gas it hesitates but manages to stay alive ..kind of!
i'm just lost and dont know what it could be!
sahdra
PostPosted: Sat Jul 23, 2011 3:35 pm Up
cars running fine so i fixed something but no satisfaction as i dont know what i've done lol
problem is now.. when i try open the car up a little and put my foot down i get 'antipollution fault' and i am limited in the amount of throttle i can give it.
P0121 - Throttle Position Sensor/Switch A Circuit Range/Performance Problem.
...any ideas what could be my issue and what i can do, seems i'm constantly taking 2 steps backwards and i'm hping this is the last of it Smile
EDIT: getting it on the computer i can clear the fault and continue my journey until it happens again but cant put my finger on what it is
sahdra
PostPosted: Mon Jul 25, 2011 3:27 am Up
...does anyone know what could be wrong? or even know where the Throttle Position Sensor is on a 180?
Could it be possible the problem is in the pedal box as there must be some kind on a sensor that sends the reading to the throttle body? ...could be in need of a clean?
