Online Now [1112]:
Visitors: 1112
Today: 172845
Total: 151658224
Forums › The Car › 206 Talk › Wipers water
Wipers water
Forum Index › 206 Talk
egouder
PostPosted: Sat Jul 23, 2011 6:46 am Up
I need to change the water of my wipers since for some reason it really stinkss :S.
Any one knows a way to empty the water pleasE?
thanks
myke
PostPosted: Sat Jul 23, 2011 6:51 am Up
you could get a fluid syphon that has a pump on it, i did it a while ago and it worked well. or you could just keep running the washer jets but then you're running the risk of burning out the motor so the best bet is to get a syphon orrr i think you can disconnect the pipe at the bottom?
Werdnal
PostPosted: Sat Jul 23, 2011 8:25 am Up
Make your own syphon with some piping. Suck through enough water to fill the pipe, and drop the end lower than the bottle level and it will syphon out by itself.
If you use a proper washer additive when you fill the bottle, water won;t turn stagnant.
