Latest: tc.206
Overall: 17147
Online Now [160]:
Visitors: 159
Today: 22788
Total: 116368273
Forums › The Car › 206 Problems › Squeaky brakes!
Squeaky brakes!
lmilligan
PostPosted: Fri Jul 29, 2011 2:22 am Up
Hi everyone, i have the squeakiest brakes known to man! Had a recent pad change and everything was fine for about a week but know they squeak and its so bloody annoying! I cleaned my discs the other day and it stopped it for about an hour then it came back Sad Has anyone got any suggestions?
PostPosted: Fri Jul 29, 2011 3:20 am Up
Did you apply cooper slip to the back of the pads when they were changed?
PostPosted: Fri Jul 29, 2011 3:25 am Up
Did you buy cheap pads?
Scootymad
PostPosted: Fri Jul 29, 2011 3:34 am Up
Did you abuse them?
lmilligan
PostPosted: Fri Jul 29, 2011 3:39 am Up
I got someone I knew to do them because I didn't have the time to do them myself! I'll have a look later and pput some on! They haven't been abused either Smile
PostPosted: Fri Jul 29, 2011 3:41 am Up
Delphi pads have anti squeel shims attached.
lmilligan
PostPosted: Fri Jul 29, 2011 4:41 am Up
Is that like a thin piece of metal that goes on after the pad?
PostPosted: Fri Jul 29, 2011 4:48 am Up
Yeah they can be, the delphi one have like a neoprene surface on the back of the pad
PostPosted: Fri Jul 29, 2011 5:08 am Up
did you bedded in the pad?
lmilligan
PostPosted: Fri Jul 29, 2011 5:13 am Up
Ah i see! On one of my calipers I have a thin metal plate that goes on after the pad? Only on the drivers side caliper though. And yeah I carefully bedded them in for like 200 miles Smile
panzer360gti
PostPosted: Fri Jul 29, 2011 5:25 am Up
I think brakes were designed to squeal just to p@ss drivers off.
Grease the buggers, sand 'em, should quiet down after a while.
Peugeot 206 GTI 137 2.0
lmilligan
PostPosted: Fri Jul 29, 2011 5:36 am Up
Yeah man seems that way! Trust me it makes my car a real head turner Wink
PostPosted: Fri Jul 29, 2011 5:37 am Up
you need to brake hard but not overheating the pad when bedding in the pad
lmilligan
PostPosted: Fri Jul 29, 2011 5:53 am Up
Ah man I was told to use the brakes nice and gentle! Do you think that could be problem?
Werdnal
PostPosted: Fri Jul 29, 2011 6:12 am Up
Cheap pads are brittle and go shiny. I had this when bought my 206 last year. I live out in the sticks, but at the bottom of a long hill and neighbours could hear me coming half a mile away! Previous owner had pads done for MOT but suspect he used "cheap and cheerfuls" - when we took them off you could almost see your face in them, they were so polished!
Changed to good quality pads, which also have a chamfered leading edge (supposed to prevent vibration which adds to to noise), and not a squeal since!
