Latest: sparrowdclxvi
Overall: 17139
Online Now [167]:
Visitors: 166
Today: 15114
Total: 112699158
Forums › The Car › 206 Problems › rear suspension soft
jaybooooi
PostPosted: Sat Jul 30, 2011 2:16 am Up
Hey everyone , need a bit of help my rear suspension is really soft, I know its the torsion bars on the rear, I have already put uprated shocks on the rear,this did not seem to help but this did not seem to help, is there anyway I can adjust the rear setup to get more torsion out of the bars or shall I get uprated bars thanks Smile
panzer360gti
PostPosted: Sat Jul 30, 2011 2:35 am Up
I think its the torsion bar that needs doing, I have uprated ones and its stiff as hell!
Peugeot 206 GTI 137 2.0
jaybooooi
PostPosted: Sat Jul 30, 2011 2:55 am Up
cheers buddy , i have lowered the car, but im not sure how to get the torsion bars completely out any ideas? Smile
Lecktorious
PostPosted: Sat Jul 30, 2011 3:04 am Up
Trade Rating: +59
Check the how-to section...
'98 Nile Blue 306 GTi 6
PostPosted: Sat Jul 30, 2011 3:11 am Up
You can shocks that are rock solid you really don't need uprated torsion bars for road use. Just get some stiffer shocks.
PostPosted: Sat Jul 30, 2011 4:22 am Up
Completely and utterly incorrect. Dampers and torsion bars (springs) do different jobs and you can't increase the rate of one to make up for a shortcoming with the other.
Dampers don't reduce bodyroll, they don't decrease lift at the rear under braking. Uprated springs/torsion bars can achieve these things.
PostPosted: Sat Jul 30, 2011 2:40 pm Up
That was completely going off the point, I'm assuming the OP wanted to use it just for road use and going mainly on the statement 'I fitted aftermarket shocks and it didn't make a difference'
If you fitted new shocks and you didn't notice the difference between them and oem I think it's logical to invest in different shocks, not go onto torsion bars.
Keeping it nice and simple, not getting into an engineering debate.
jaybooooi
PostPosted: Sun Jul 31, 2011 1:09 am Up
Okay cheers guys what shocks do you have that are rock solid , what are they called? As I've already got uprated ones on the back and it made no difference ?
Signature removed due to size
PostPosted: Sun Jul 31, 2011 1:19 am Up
Just do the job properly and fit some GTi 180 torsion bars.
PostPosted: Sun Jul 31, 2011 3:56 am Up
or drop the rear and let it sit on the bump stop. then the rear will be rock solid hard Laughing
Goldin
PostPosted: Sun Jul 31, 2011 4:03 am Up
Try for a start uprate your ARB with the GTi 180 ARB, that made a huge differece on my car.
The rear suspension became stiffer in corners, and it reduced bodyroll.
It was a big difference and very noticeable even on my old shocks.
PostPosted: Sun Jul 31, 2011 4:22 am Up
But an antil roll bar doesn't reduce vertical movement in any way.
PostPosted: Sun Jul 31, 2011 5:19 am Up
i must say i put on some rear shocks that came with my coilovers and the rear end was defiantly harder, Confused
macj
PostPosted: Sun Jul 31, 2011 5:32 am Up
I have a brand new GTi rear ARB for sale..... £50 + postage
jaybooooi
PostPosted: Mon Aug 01, 2011 3:24 am Up
Yeah I've got coilovers and have got the shocks that came with them on the back but there is hardly any difference? Where could I get the gti 180 torsion bars then? Smile
