Latest: heikkisj
Overall: 17126
Online Now [59]:
Visitors: 58
Today: 20036
Total: 100303946
Forums › The Car › 206 Problems › 2 small faults, APF and ABS
McFall1984
PostPosted: Sat Jul 30, 2011 6:13 pm Up
i bought my 2001 2ltr hdi d-turbo 206 there last week
has no exhaust apart from downpipe an backbox
complete middle section gone
since i got the car home it flashed up anti-pollution fault an engine management on the dash lite up
also the abs light came on the display and dash
so i bought a centre cat repair pipe ( no cat ) an a bit of exhaust pipe to complete the exhaust
got all on but still got the anti-pollution light
does this need cleared an is that the problem sorted?
ABS light
when we were at the exhaust we noticed the driver side abs sensor wire joined with 2 connectors, would that be the abs problem sorted to?
can they be joined or do i need a new sensor?
currently owns\r\n93 cavalier saloon\r\n01 206 hdi d-turbo
Harty
PostPosted: Sun Jul 31, 2011 4:39 am Up
fault needs to be cleared and checked for any others while your at it, mine used to go away and come straight back like it would flash off then straight back on so i knew there was other problems. as for the abs sensor wire is it scotchlocks? if so i would replace them with some soldering and heatshrink wrap and it might be the cure Smile
Harty
McFall1984
PostPosted: Sun Jul 31, 2011 6:45 pm Up
yea must get the abs sensor done right an hope that cures that fault
i'll update when all done an put on the diagnostics
