Online Now [343]:
Visitors: 342
Today: 117976
Total: 156224535
Forums › The Car › Request a how-to › How to remove a Peugeot windscreen washer pump
shady
PostPosted: Tue Aug 02, 2011 3:00 am Reply with quote Up
hi:
i am shady , i have a leakage in my windscreen washer pump so i need to remove it .. and then fix it by myself .
can anyone here show me the way (step by step) to remove this pump , or you can give me a site in which i can get pictures about how to remove it !?
shady
PostPosted: Tue Aug 02, 2011 4:04 am Reply with quote Up
Take the drivers arch liner out. Disconnect the pipes. There is either one or two 10mm bolts that hold the bottle in place.
On a side note, did you buy a speedo from me on ebay yesterday?
Rob2859
PostPosted: Tue Aug 02, 2011 9:34 am Reply with quote Up
If it is leaking from where the pump fits the water tank just twist and pull the pump off and put some silicone around the pump and push it back on. no need to remove the tank unless its cracked.
shady
PostPosted: Thu Aug 04, 2011 4:26 pm Reply with quote Up
I think its probably cracked !! But my ques. is from where should i take off the tank from down the car or from inside (under. the hood)?? Cause i think its hard to take it off from inside ?
shady
Rob2859
PostPosted: Sat Aug 06, 2011 7:26 am Reply with quote Up
Not sure to be honest. Take the arch lining off and you should be able to see. I would put water in it first and see where the leak is before you bother taking it out
shady
PostPosted: Tue Aug 09, 2011 2:40 am Reply with quote Up
the thing is that i have done this step , but still don't know where the water comes from ! it's from inside i guess. so anyway i have to remove it .
shady
  Quick Reply
Username:
Message:
Quote the last message
