Online Now [622]:
Visitors: 621
Today: 123866
Total: 155603588
Forums › The Car › 206 Problems › Clutch replaced but still can't select gears
sealgaire
PostPosted: Tue Aug 02, 2011 4:03 am Up
Hi,
Car came to a stop last week when I couldn't select any gear. I was able to select gears when the engine was turned off however.
I replace the clutch, pressure plate and release bearing.
Now I still have the exact same problem.
Did i get a new faulty pressure plate?
Any ideas?
sdgsdg
PostPosted: Tue Aug 02, 2011 4:15 am Up
gear linkage or cable.
what car is yours?
sealgaire
PostPosted: Tue Aug 02, 2011 4:24 am Up
1999 1.1 206.
The teeth or springs on the new pressure plate are slightly up on one side.
sdgsdg
PostPosted: Tue Aug 02, 2011 4:57 am Up
what do you mean by you can't select any gear?
you can't move the gear stick? it can move but it won't go into gear?
sealgaire
PostPosted: Tue Aug 02, 2011 5:04 am Up
Hi,
Yea, with the engine off the car will go into gear. But when the engine is running I cannot get the gearstick to select any gear.
sdgsdg
Mrs_Howey
PostPosted: Tue Aug 02, 2011 5:14 am Up
Try changing the clutch cable.
Moonstone blue 206 1.4look
pro race 1.2 White
Morettes
GTI wings
TEAM: Carbon Fibre Very Happy
sealgaire
PostPosted: Tue Aug 02, 2011 5:19 am Up
does the clutch cable need to be adjusted after the new clutch is fitted? or is it self adjusting?
sdgsdg
Mrs_Howey
PostPosted: Tue Aug 02, 2011 5:21 am Up
Its self adjusting.
pro race 1.2 White
Morettes
GTI wings
sealgaire
PostPosted: Tue Aug 02, 2011 5:27 am Up
ok, clutch cable is only about a year old though. I nearly went mad when it didn't work! Smile
sdgsdg
sealgaire
PostPosted: Tue Aug 02, 2011 8:58 am Up
is there a rachet on the clutch cable that allows it to be tighten up? near where it enters the bulkhead?
sdgsdg
Mrs_Howey
PostPosted: Tue Aug 02, 2011 9:09 am Up
No it's all one cable and does it itself Smile
Could be the syncromesh in the gearbox
pro race 1.2 White
Morettes
GTI wings
-RAJ-
PostPosted: Tue Aug 02, 2011 12:50 pm Up
does the clutch pedal make a clicking kind of noise when pressed? could be the cable then, the springs in the adjuster can mess up and not release. same thing happened to me and it was a new cable job
sealgaire
PostPosted: Tue Aug 02, 2011 3:28 pm Up
hi, i fitted the LUK clutch kit and hey presto it works. BUT it isn't right. The release point on the clutch is extremely high and in each gear when i hit about 3000 revs it just revs out beyond that itself but no power. any ideas?
sdgsdg
PostPosted: Tue Aug 02, 2011 3:31 pm Up
looks like the clutch is not engaging properly
sealgaire
PostPosted: Tue Aug 02, 2011 3:52 pm Up
could that be related to the high release point and stiffness on the pedal? cable related?
sdgsdg
