Latest: eltel666
Overall: 17146
Online Now [81]:
Visitors: 80
Today: 6718
Total: 116143775
Forums › The Car › 206 Talk › Guess what I'm doing Today???
00budham00
PostPosted: Thu Aug 04, 2011 4:42 am Up
anthony_839
PostPosted: Thu Aug 04, 2011 4:43 am Up
lowering car.
euroed astra
Big_Rich180
PostPosted: Thu Aug 04, 2011 4:45 am Up
Torsion bar.
xspongerx
torsion bar
PostPosted: Thu Aug 04, 2011 4:47 am Up
Torsion bar
00budham00
PostPosted: Thu Aug 04, 2011 4:49 am Up
Club hammers a dead give away! And most people have to resort to a flame to speed things up.lol
Such a gash job !
PostPosted: Thu Aug 04, 2011 4:50 am Up
Good luck.
I couldn't shift mine with a 15kg sledge.
Slide hammer if I had to do it again.
Abzynthe
PostPosted: Thu Aug 04, 2011 4:51 am Up
East Area Rep - Abzynthe
you might want to charge your battery at some point Razz
00budham00
PostPosted: Thu Aug 04, 2011 5:11 am Up
CD-530d wrote:
Good luck.
What was the outcome? Did you use heat On the trailing arm? Isn't a 30mm socket, washer and bolt better or same as slide hammer ?
PostPosted: Thu Aug 04, 2011 5:13 am Up
00budham00 wrote:
CD-530d wrote:
Good luck.
I used heat & penetrating oil (not at the same time Laughing )
I gave up in the end after hitting it for 2 hours. I wasn't aware of the socket method at the time.
kieron
PostPosted: Thu Aug 04, 2011 5:20 am Up
I did mine yesterday when i refurbed the rear axel, but with a 8kg slege it came out in 5 hits! but the traling arm fell off because it was the knackard!
Account suspended
00budham00
PostPosted: Thu Aug 04, 2011 5:24 am Up
is this common?
kieron
PostPosted: Thu Aug 04, 2011 5:29 am Up
Depends if your bearings are worn
Account suspended
00budham00
PostPosted: Thu Aug 04, 2011 5:45 am Up
Did they just side back on ? Nothing going o spring out on me lol?
PostPosted: Thu Aug 04, 2011 5:55 am Up
Lol you will know if the trailing arms come off they have to move quite a lot
