Online Now [427]:
Visitors: 426
Today: 113156
Total: 157302265
Forums › The Car › 206 Talk › Max. oil level
Max. oil level
Forum Index › 206 Talk
Ben.M
PostPosted: Fri Aug 05, 2011 10:35 am Up
My oil level is slightly over the max. on the dipstick, is this bad??? I know the limits are there for a reason but i've driven about with it at this level with no issues however i'm just worried that it may be doing harm to the engine.
Thank you Very Happy
PostPosted: Fri Aug 05, 2011 10:39 am Up
Petrol engine - I wouldnt really worry about it if its only just slightly over.
Diesel engine - Drain the level back down to MAX ASAP.
PostPosted: Fri Aug 05, 2011 10:40 am Up
Is it definitely on flat ground first?
And you've let it all settle?
Ben.M
PostPosted: Fri Aug 05, 2011 10:44 am Up
1.1 petrol, I might drain it down a little for peace of mind when I've got the time but as long as its safe for then engine then i'm happy.
Yes Lee, on a flat surface the level is about 2mm over max. on the dipstick. The dash oil warning is useless tho, one day it will say its full, the next empty so I can just go by the dipstick.
Thanks Very Happy
PostPosted: Fri Aug 05, 2011 10:45 am Up
Thanks Very Happy
2mm over the max, dont worry about it.
As for the oil level gauge - a BSI software update will cure that.
PostPosted: Fri Aug 05, 2011 10:46 am Up
2mm? I wouldn't bother Laughing
Ben.M
PostPosted: Fri Aug 05, 2011 10:47 am Up
Great, thanks both of you Smile
