Online Now [582]:
Visitors: 581
Today: 108468
Total: 154919191
Forums › The Car › 206 Problems › Car totally died on me when driving, full details inside ;)
Go to page Previous  1, 2, 3
Andy180+
PostPosted: Sat Aug 06, 2011 2:33 pm Up
the earth strap from the battery to the gearbox and the body of the car
it will be trying to earth via everything
loudnproud
PostPosted: Sat Aug 06, 2011 2:38 pm Up
check main earth strap from battery mine did same ( cut out and sometimes electrics went mad) and turned out earth strap had snapped and was swinging around down in the engine bay,not saying it is this but worth a try i just used some 0 awg wire from my amp kit,
GTI_89
PostPosted: Sat Aug 06, 2011 2:41 pm Up
will go take a look before it gets to dark
Im New, Go Easy On Me Very Happy
PostPosted: Sat Aug 06, 2011 2:45 pm Up
Andy180+ wrote:
i said that lol
I was emphasising it Razz
Along with the 4 million others that have said the same lol
If you need a earth strap give me a shout, should have one somewhere in my stash
PostPosted: Sat Aug 06, 2011 2:46 pm Up
GTI_89 wrote:
Lee wrote:
Earth strap.
The relays clicking will be from the poor connection not giving enough power.
earth strap where though?? there must be hundreds of them!
the relays have actually stopped clicking now and when you try somthing like the wipers or lights it either doesnt work, kills the poker to everything else or works but not fully :S
what would explain the smoke though??
wish it was just somthing simple as i really need to car for monday morning lol
main earth strap is negative battery terminal to gearbox
Andy180+
PostPosted: Sat Aug 06, 2011 2:48 pm Up
Lee wrote:
Andy180+ wrote:
i said that lol
Thumbs Up
Andy180+
PostPosted: Sat Aug 06, 2011 2:49 pm Up
if its broken ask a mechanic lol normally helps
oooppps did i type that ????
GTI_89
PostPosted: Sat Aug 06, 2011 2:58 pm Up
right you bunch of cocky fookers lol
Thank you VERY VERY MUCH for all your help but yes its the earth strap lol
it has snapped from the gearbox to the body.
i rested it in place and tried again an boom started first time Very Happy
ok im not the brightest and it may of took 3 pages but i know whats up now and will sort it tomorow Very Happy :D
thanks again (cheeky tw*ats Wink ;) )
Karl.
Andy180+
PostPosted: Sat Aug 06, 2011 3:07 pm Up
nah nah nah nah nah nah lol pmsl
GTI_89
PostPosted: Sat Aug 06, 2011 3:14 pm Up
well least you can go to bed tonight happy in the knowledge that you helped a fellow 206info simpleton
shell-vt
PostPosted: Sat Aug 06, 2011 3:15 pm Up
Trade Rating: +46
keep smilin karl....
york 16,3
PostPosted: Sat Aug 06, 2011 3:26 pm Up
Very Happy
Andy180+
PostPosted: Sat Aug 06, 2011 3:28 pm Up
thats what we are here for Karl, no worries pal
Rob2859
PostPosted: Sat Aug 06, 2011 6:07 pm Up
GTI_89 wrote:
tomd0801754 wrote:
I would get codes read first, or wait unil one of the Lee's sees this post as they are the experts.
However if it is a new ECU you will need: ECU, key with transponder, and all the locks.
ok i will do.
ok well i should easily be able to get all that from a breakers yard.
when you say all the locks, would that be ignition barrel, doors and boot??
as surely the doors would just work of the keyfob and not need the locks changed but obviously keep the old key incase i needed it...?
not quite right. Just did mine. New ECU, BSI and transponders are needed. No need for the locks.
Chris_38
PostPosted: Thu Jun 13, 2013 11:17 am Up
Did u sort this issue out I've jus had the same thing happen to me today
If its not broke why fix it ,
Page 3 of 3
