Posted: Mon Aug 08, 2011 3:20 pm |
any ideas????
Posted: Mon Aug 08, 2011 3:22 pm |
Posted: Mon Aug 08, 2011 3:25 pm |
i cant do the b pillars on mine cuz there plastic right?
Posted: Mon Aug 08, 2011 3:47 pm |
wheel arch extensions if you havent got the factory sp kit! set the car off nice
Posted: Mon Aug 08, 2011 4:02 pm |
Kool ill look it up anything to sprouse the interiour up
My car looks really tired as it is now
Posted: Mon Aug 08, 2011 4:04 pm |
Should be able to remove the B pillar vinyl on any 206
dafdavies wrote: |
i cant do the b pillars on mine cuz there plastic right? |
read the link and youll find out if theyre plastic or not.......
| NO LONGER ACTIVE ON THE FORUM | |
Posted: Mon Aug 08, 2011 4:15 pm |
Okay I jus wanted to be sure if I go taking them off and screw it up
Posted: Mon Aug 08, 2011 4:16 pm |
dafdavies wrote: |
Okay I jus wanted to be sure if I go taking them off and screw it up |
Pull the vinyl off from behind the door to be sure its painted first, but they will 100% NOT be made of plastic, i can assure you of that!
What colour is your car?
Posted: Mon Aug 08, 2011 4:21 pm |
Gray
Posted: Mon Aug 08, 2011 4:24 pm |
yeah pull the vinyl off if its grey, itll look better.
Posted: Mon Aug 08, 2011 4:26 pm |
Okay thanks pal anything I can do about the black bits on the bumpers the rear one faded
Posted: Mon Aug 08, 2011 4:41 pm |
you can either spray them, clean and use back to black, use peanut butter or heat gun them. Search on youtube for the heat gun method
Posted: Mon Aug 08, 2011 4:46 pm |
Okay will do ill post some pics of it tomorrow and show how its going along
Posted: Tue Aug 09, 2011 7:09 am |
