Posted: Tue May 03, 2011 11:32 am |
Edward wrote: |
Davels wrote: |
I'm I right |
No.
Later cars have 2 x lambdas. Which car has more power I have no idea. I believe RFN coded cars might actually be 136bhp and the early ones 137/138bhp. |
multiplexing adds 1bhp to the GTi, that's all you need to know Eddie
it also made it faster accelerating and more economical, if 1mph slower.
maybe the gearing was changed? or compression ratio?
it appears that it was to do with emissions
reem
Posted: Tue May 03, 2011 1:01 pm |
The RFN cars with 2 lambdas were nothing to do with multiplexing.
Posted: Tue May 03, 2011 1:12 pm |
Edward wrote: |
The RFN cars with 2 lambdas were nothing to do with multiplexing. |
okay
was the later engine RFR? If so they are multiplexed and are 138bhp.
pre-multiplexed cars have 137bhp and are 1mph faster.
Posted: Tue May 03, 2011 1:15 pm |
that hasn't helped
Posted: Tue May 03, 2011 1:25 pm |
Barking wrote: |
Edward wrote: |
okay
pre-multiplexed cars have 137bhp and are 1mph faster. |
Read my first post and you'll find earlier GTi's were RFR coded. You can get multiplexed and conventionally wired RFN's!
Multiplexing has nothing to do with engine outputs.
Posted: Tue May 03, 2011 1:27 pm |
Edward wrote: |
Barking wrote: |
Edward wrote: |
okay
Multiplexing has nothing to do with engine outputs. |
from Peugeot-psa website
"The 206 GTi was available in UK showrooms from 01 June 1999.
The GTi was originally 137bhp but when multiplexing was introduced(11 Oct 2001 onwards) it produced 138bhp. The pre-multiplexed GTi's have higher emissions, so you will probably pay more roadtax"
Posted: Tue May 03, 2011 1:30 pm |
Posted: Tue May 03, 2011 1:31 pm |
Well you can get Y plater 138 GTi's that were non-multiplexed that have the same emissions as multiplexed cars. The statement quoted is inaccurate.
Posted: Tue May 03, 2011 1:39 pm |
Edward wrote: |
Well you can get Y plater 138 GTi's that were non-multiplexed that have the same emissions as multiplexed cars. The statement quoted is inaccurate. |
Eddie. Let's call it quits?
Neither engine has ever been 137bhp or 138bhp from factory anyway
Posted: Wed Aug 10, 2011 3:49 pm |
Early GTI's had the aerial at the front of the roof as opposed to the rear. And display on dash does not tell you station on early version, unless the display on the missus' car is knackered.
Posted: Wed Aug 10, 2011 5:56 pm |
My car is a 51 and its pre-plexed.
Reg date was September IIRC
| 206 GTI
Nimrods
SP Grille
Cargo Net!
Team: Old school member since May 2006 - 3k posts lost
Leader Team: Tivoli GTI
Leader Team: Cargo Net
Snowboard & Bindings For Sale
www.goneboarding.co.uk...ified.aspx | |
Posted: Thu Aug 11, 2011 1:02 am |
the interior did change at some point... they changed the tops of the front seats to have leather aswell.. so from this
to this
quite subtle but still effective to me
Posted: Fri Aug 12, 2011 11:42 am |
Windscreen wipers are different sizes on early version, but thats probably all ealy 206's.
