Latest: dreyfalon
Overall: 17121
Online Now [304]:
Visitors: 303
Today: 13274
Total: 97693853
Forums › The Car › 206 Problems › warning lights problem
lmilligan
PostPosted: Sat Aug 13, 2011 5:13 am Up
So I was driving down the road and my speedo cut out, all warning lights come on and was flashing stop again Sad I've taken it to peugeot now and going to get a full diagnosis scan on what the cause is!
PostPosted: Sat Aug 13, 2011 5:56 am Up
Will be either:
BSI software
Loose conenction in the CAN VAN wires between instrument cluster & BSI unit.
I get the feeling you will get charged an hours labour for updating the BSI & ecu software.
magistar
PostPosted: Sat Aug 13, 2011 6:08 am Up
i have the exact same problem :s though mine is a really rare intermiten problem so i havent gotten around to fix it yet.
what exactly is the can van cable?
PostPosted: Sat Aug 13, 2011 6:12 am Up
Check the following AFTER shutting down the BSI correctly & disconnecting the battery!
On the BSI unit:
Black 10 way connector. Terminal 8 wire 9004 and terminal 10 wire 9005.
On the instrument cluster:
Blue 18 way connector terminal 4 wire 9004 and terminal 2 wire 9005.
Clean & check all these 4 terminals, make sure there a tight fit.
lmilligan
PostPosted: Sat Aug 13, 2011 6:17 am Up
I asked the guy at pug and he said a software update will only turn the engine management light off? Ill keep you updated on what it is
magistar
PostPosted: Sat Aug 13, 2011 9:33 pm Up
On the BSI unit:
Thanks. I'll have a look at it when I have time. Though since my problem comes on on rare occasions it'll be hard for me to check if it really does solve it.
Interestingly my problems only seem to occur during winter so my guess is that im having a connection issue. with all that colder connections and w/e.
And yes do keep this updated. Would be good to know.
