Latest: jtq4u
Overall: 17141
Online Now [203]:
Visitors: 202
Today: 43304
Total: 113950356
Forums › The Car › 206 Problems › soft constant whistling sound
bisphenol-a
PostPosted: Sat Aug 13, 2011 3:13 pm Up
i get this sound whenever the engine is running but its very soft. i cant hear it when im driving, i can only hear it when im stationary and i lean my head forward to the steering wheel. i will then hear this constant whistling sound that will never cut.
it only cuts when i cut the engine then when i start the engine again it comes back, tested it at the drive way when i got home.
just really curious what is whistling the whole time.
ukskater01
PostPosted: Sat Aug 13, 2011 3:41 pm Up
What engine do you have?
pug206lx
PostPosted: Sat Aug 13, 2011 4:29 pm Up
Is it coming from the passenger side footwell?
If it is then im going with brake servo leaking air
bisphenol-a
PostPosted: Sun Aug 14, 2011 8:07 pm Up
i drive a gti138
i dont know if the passenger side has the sound
will check it out
zoranm1976
PostPosted: Sat Aug 20, 2011 12:21 pm Up
It is brake servo gone it has little hole inside. I had whistling sound now is more like air clutch or brake on buses. When I touch brake just to make brake lamps on sound is gone. Newer the less brake is still working after almost 1 year.
Mid 2002 206 1.4i XS LPG converted
