Latest: ArtistKS
Overall: 17145
Online Now [51]:
Visitors: 50
Today: 41026
Total: 115940676
Forums › The Car › 206 Problems › Boot seized or locked shut and cant open
Simmo
PostPosted: Mon Aug 15, 2011 11:57 am Up
My boot has recently seized shut, locked shut or even jammed shut some how? Has anyone else had the same problem and how can I solve it? My car is a 1.1 style 2001 Question
1.1 silver style www.206info.co.uk/Foru...52484.html
PostPosted: Mon Aug 15, 2011 12:26 pm Up
You tried opening from the inside?
dafdavies
PostPosted: Mon Aug 15, 2011 1:23 pm Up
worth a try! What He Said What He Said
Team: If you cant find the tool you need make one
drew
PostPosted: Mon Aug 15, 2011 2:52 pm Up
mine does it all the time, just have to push the handle in really hard, but yeah worth having a look at it from the inside see how the mechanism works see if there's anything obstructing it/anything broken.
Black 1.4 lx, you can only tell when it's moving....
Simmo
PostPosted: Fri Aug 19, 2011 10:21 am Up
my 206 doesnt have a leaver on the inside, unless you mean from inside of the boot?
Abzynthe
PostPosted: Fri Aug 19, 2011 10:23 am Up
East Area Rep - Abzynthe
Is there access to the boot catch from inside the boot? If so you could unbolt the catch from the car and then lift the boot and examine the fault that way?
PostPosted: Sat Aug 20, 2011 5:50 am Up
You need to unclip the plastic trim panel on the inside of the tailgate to get at the lock & handle assembly / open the boot.
Simmo
PostPosted: Tue Sep 20, 2011 8:44 am Up
Th boot came un-seized eventually but stuck again the next day, the clip looks fine and the mechanism, could it possibly be the remote central locking fault?
PostPosted: Fri Sep 23, 2011 12:28 am Up
As above and soak it with silicone-grease spray once open.
