Online Now [465]:
Visitors: 464
Today: 136898
Total: 156851714
Forums › The Car › 206 Problems › 206 GTi "Gearbox" clonking?
tubbe2
PostPosted: Mon Aug 22, 2011 6:19 am Up
Hello!
Searched the forum, and couldn't really find anything about my specific issue.
Whenever I shift/change gears upwards (all gears 1-2-3-4-5), the car makes a clonking noise from the front - also, when I take my foot off the accelerator pedal and press it back down, it also clunks a bit, but not as much though.
To avoid this as much as I can, I have to shift/clutch really slow and as smooth as possible. Really a pain in the a**e, specially with the clutch pedal being tight - it doesn't really glide smooth. Confused
And also to mention - when I shift at high revs, around 4-5000RPM and also accelerating, it doesn't clonk as much/often, funnily enough Laughing
It doesn't make any clonking noise when I shift down.
Any help on my issue please?
2002 Peugeot 206 GTi 2.0 16v 137Bhp
Big_Rich180
PostPosted: Mon Aug 22, 2011 6:29 am Up
Gti 137...thats a new one lol.
Could be the engine mount buddy.
No need to edit your title Laughing
tubbe2
PostPosted: Mon Aug 22, 2011 6:55 am Up
Doesn't matter anyway Razz Just wanted to make it sure, that it's about the 137bhp engine, and not the "180" - as the 2.0 is sometimes also called S16 in the UK, when it's not the GTi 180? So I've read..
Big_Rich180
PostPosted: Mon Aug 22, 2011 7:01 am Up
I've heard it called the 138 and 140 so your 137 was a new one for me haha.
It sounds like a very similar thing I had on my 180 which I thought was an engine mount but it ended up being front wishbone bush that had degraded.
furryhobnob
PostPosted: Mon Aug 22, 2011 7:02 am Up
He's right I believe, there's 2 variants of the Gti, one has 137bhp the other has 138bhp
MrrNoName
PostPosted: Mon Aug 22, 2011 9:10 am Up
Get the engine mounts looked at.
A worn mount would allow the engine to rock when applying load, it could be hitting something causing the clunking
tubbe2
PostPosted: Mon Aug 22, 2011 2:39 pm Up
Anyone else have some input? Smile
I don't think the clutch has ever been changed btw (it's rounding 132k km / 82k miles soon), and the previous and only owner of the car was a woman Laughing - got a mechanic to take it for a short drive today, and he said it felt like it was the clutch, when engaging the gears. and that would be a quote of around £700 including labour Thumb Down
MrrNoName
PostPosted: Mon Aug 22, 2011 4:11 pm Up
£700! ?
To get a clutch replaced is about £250 currently, im not sure how would it be the clutch though? maybe get a second opinion before you get it replaced.
tubbe2
PostPosted: Tue Aug 23, 2011 4:44 am Up
Well, a clutch kit costs £190 in Denmark, and the garage takes around £58 per hour (which is kinda cheap here in Denmark, the Peugeot garage takes around £117 per hour) - and he said it would take most of a day Sad
At least - maybe buying a clutch kit in the UK would be smarter/cheaper - if that's the road I'm going down. The cheapest I could find was £98.47 on ebay, with £15 in shipping. Anyone knows where I can get it cheaper? And also maybe uprated, if the price stays under/equal to the Danish price - £190
I will have someone else to look at the engine mounts sometime soon...
tubbe2
PostPosted: Tue Sep 27, 2011 12:54 am Up
Please close the topic - problem was related to tired springs/worn out clutch. Clonking disappeared after fitting a new clutch. Still clonks a bit sometimes, but I guess that's an operator error Laughing
