Latest: heikkisj
Overall: 17126
Online Now [211]:
Visitors: 210
Today: 21099
Total: 100354060
Forums › The Car › 206 Problems › fitting crystals to pre-plex 2001 not the usual questions :P
PostPosted: Mon Aug 22, 2011 1:28 pm Up
not the usual do they fit question Laughing
the h7 plugs are there but i know from a previous similar aged 206 they work but when main is put on dip goes out and i had to wire a relay in. now just been thinking if the plugs are there and live is the circuit for the relay there too meaning i can just stick in the correct relay and bobs your uncle fully working crystals??
PostPosted: Mon Aug 22, 2011 1:30 pm Up
Pre plex are simple - Change the headlamp stalk to GTI double optic spec OR get Lee to tweak your original stalk.
No need for w**ky adaptors or wiring relays in, the secret is in the headlamp stalk Wink
PostPosted: Mon Aug 22, 2011 1:33 pm Up
so i can plug the crystals straight into the h7 plugs that are tucked up behind the wings and swap just the light stalk for a gti one and they will work spot on? Smile
PostPosted: Mon Aug 22, 2011 1:35 pm Up
Yes Cool
Non plexed 206's are so simple to convert
The dipped & main beam relays are both already there, its just the way the different headlamp stalks control them that is the issue Wink
Lee does do a stalk conversion service if you want to keep the original stalk but he is on holiday.
PostPosted: Mon Aug 22, 2011 1:38 pm Up
cheers mate that awesome Smile
its for the other half car and wont be fitting the lights for a few weeks anyway so il just buy one off ebay unless the scrappy has one on sat Smile
thanks for the help Smile
PostPosted: Mon Aug 22, 2011 1:41 pm Up
If she hasnt got front fogs fitted then remind her it will now be 2 clicks for the rear fog lamp Wink
MrrNoName
PostPosted: Mon Aug 22, 2011 1:44 pm Up
I just fitted an additional relay into the headlamp wiring, took less then 5 minutes, I like my original stalk Razz
oh yeah cheers mate Smile hopefully get some of those on in due course too Cool
PostPosted: Tue Aug 30, 2011 11:48 am Up
The stalks look the same. I just modify the circuit board Wink
