Posted: Mon Aug 22, 2011 1:28 pm |
not the usual do they fit question
the h7 plugs are there but i know from a previous similar aged 206 they work but when main is put on dip goes out and i had to wire a relay in. now just been thinking if the plugs are there and live is the circuit for the relay there too meaning i can just stick in the correct relay and bobs your uncle fully working crystals??
Posted: Mon Aug 22, 2011 1:30 pm |
Pre plex are simple - Change the headlamp stalk to GTI double optic spec OR get Lee to tweak your original stalk.
No need for w**ky adaptors or wiring relays in, the secret is in the headlamp stalk
Posted: Mon Aug 22, 2011 1:33 pm |
so i can plug the crystals straight into the h7 plugs that are tucked up behind the wings and swap just the light stalk for a gti one and they will work spot on?
Posted: Mon Aug 22, 2011 1:35 pm |
rttam wrote: |
so i can plug the crystals straight into the h7 plugs that are tucked up behind the wings and swap just the light stalk for a gti one and they will work spot on? |
Yes
Non plexed 206's are so simple to convert
The dipped & main beam relays are both already there, its just the way the different headlamp stalks control them that is the issue
Lee does do a stalk conversion service if you want to keep the original stalk but he is on holiday.
Posted: Mon Aug 22, 2011 1:38 pm |
cheers mate that awesome
its for the other half car and wont be fitting the lights for a few weeks anyway so il just buy one off ebay unless the scrappy has one on sat
thanks for the help
Posted: Mon Aug 22, 2011 1:41 pm |
If she hasnt got front fogs fitted then remind her it will now be 2 clicks for the rear fog lamp
Posted: Mon Aug 22, 2011 1:44 pm |
I just fitted an additional relay into the headlamp wiring, took less then 5 minutes, I like my original stalk
Any work you undertake as a result of my posts is done so at your own risk | |
MrBSI wrote: |
If she hasnt got front fogs fitted then remind her it will now be 2 clicks for the rear fog lamp |
oh yeah cheers mate hopefully get some of those on in due course too
Posted: Tue Aug 30, 2011 11:48 am |
MrrNoName wrote: |
I just fitted an additional relay into the headlamp wiring, took less then 5 minutes, I like my original stalk |
The stalks look the same. I just modify the circuit board
