Latest: tbafonso
Overall: 17130
Online Now [138]:
Visitors: 137
Today: 29994
Total: 103146767
Forums › The Car › 206 Problems › just failed M.O.T
just failed M.O.T
Tam80
PostPosted: Thu Aug 25, 2011 4:03 am Up
failed on
001 offside front constant velocity joint gaiter split
002 brake load sensing valve linkage seized
003 exhaust emissions lambda reading after 2nd fast idle outside specified limits
004 nearside rear road wheelbead rim badly distorted
005 parking brake efficiency below requirements
replace cv joint i can do
whats the brake load sensing valve and where is it ?
its got a big metal cone on it just now so will removing that going back to the original box make any difference ? think it was 0.41% out..anybody any other ideas on whats the cause of this if doing the above dont work ?
will be changing alloys and brakes at the weekend...going down to 15" till i get my 17" refurbed and get new tyres..got full new set of grooved/drilled discs all round/mintex pads.. that will be getting done on saturday
then adjust handbrake Thumb Up
should be done over the weekend barring any problems (fingers crossed) lol
cheers again guys Wink
206/GT/GTI
M60SHW
PostPosted: Thu Aug 25, 2011 4:13 am Up
1, it's just the rubber there like £5 put a new one on.
2, load sensor is I think on the back axle it's a little box with 2 springs just lube them up an give it a wriggle till it's free (if I remember correctly)
3, change the filter, if not then a good service, if not new cat
An the rest you seem to have sorted Smile
Team, ST
Team, Gti 138 track slag
Rob2859
PostPosted: Thu Aug 25, 2011 4:16 am Up
The brake valve is on the back axle at one side. Follow your brake pipes to the end and that is it. I just replaced mine, cost me £5 from a scrap yard. You may be able to free it if you soak it with brake cleaner or even better brake fluid, just don't get brake fluid on your paint.
kieron
PostPosted: Thu Aug 25, 2011 4:34 am Up
Give her a good oil and filter change and airfilter and maybe plugs, its also worth using premium fuel next time as it cleaner burning
Account suspended
PostPosted: Thu Aug 25, 2011 5:29 am Up
M60SHW wrote:
13, change the filter, if not then a good service, if not new cat
Or a leaky exhaust pipe somewhere. Look for the simple fixes first rather than the expensive ones.
gti180boy
PostPosted: Thu Aug 25, 2011 5:39 am Up
INDEED
180 Doctor
Nik_GTi
PostPosted: Thu Aug 25, 2011 6:10 am Up
I always find that putting in some redex fuel treatment, topping it up with V power or the likes, then taking the car for a good spanking sorts out the emissions.
Proud 206 GTi owner....
Abzynthe
PostPosted: Thu Aug 25, 2011 6:13 am Up
East Area Rep - Abzynthe
Or getting the MOT tester to keep his foot on the accelerator while its being tested Laughing
dafdavies
PostPosted: Thu Aug 25, 2011 1:14 pm Up
The brake valve use a hammer as penetrating fluid to free it up common fault
Team: If you cant find the tool you need make one
PostPosted: Thu Aug 25, 2011 2:49 pm Up
new boot have to pop the shaft out of the drive hub to fit
plenty of wd40/oil and just work it back and forth should free up they normally do
as its just the lamda and the co waas obviously ok i would say you just have an exhaust leak
somewhere get a friend to hold a rag over the tailpipe and then listen for the hissing if its small plug
it with exhaust paste if not replace the clamp/pipe thats leaking
swap the wheel remember each axle must have the same sized wheel/tyre fitted
probably just the cables have stretched can be adjusted very simply if not check the levers on rear
calipers are operating correctly/equally
PostPosted: Thu Aug 25, 2011 3:38 pm Up
No need to take the driveshaft out. Buy a split CVJ boot kit. It comes with adhesive, clips and trimming knife (if you need it)
Takes about 5-10 minutes to fit once car is off the ground. As long as you do it properly, it will pass the MOT for a good few years.
