Online Now [348]:
Visitors: 347
Today: 166223
Total: 155257109
Forums › The Car › 206 Problems › Fuel gauge problem
Fuel gauge problem
elcamino
PostPosted: Thu Aug 25, 2011 11:39 am Up
HI.today i noticed that "distance to gas station" page on MFD shows dashes.other pages show correct values.i disconnected MFD plug and reconnected but no help.a few hours later while driving suddenly the pointer dropped to E.and amber light illuminated .while tank was almost full.any help appreciated.
el camino. "Whether you think you can or you think you can't, you're right" Henry Ford.
PostPosted: Thu Aug 25, 2011 12:00 pm Up
Try rebooting the BSI unit first, its most likely just a software glitch.
Speedo working ok?
ABS ( if fitted ) warning light not on?
elcamino
PostPosted: Thu Aug 25, 2011 12:09 pm Up
Yes everythings fine except those related to fuel quantity.no ABS warning.
PostPosted: Thu Aug 25, 2011 12:11 pm Up
BSI reboot time then & if that doesnt cure it then its up with the rear seat & remove the plastic inspection cover to get at the sender unit.
elcamino
PostPosted: Thu Aug 25, 2011 12:17 pm Up
Thanks very much.i'll try it and tell you.
elcamino
PostPosted: Fri Aug 26, 2011 2:04 am Up
Rebooted the bsi pointer came back to its actual position.but MFD still shows dashes when i select distance to gas station.
