Online Now [501]:
Visitors: 501
Today: 118064
Total: 154676142
Forums › The Car › 206 Problems › Help with this Problem !
Callum206
PostPosted: Fri Aug 26, 2011 4:35 am Up
Basically when im driving normally my car will randomly 'splutter' and lose power when it doe this, i had this before but last time i had it i had it constant this time it just happens randomly when im driving usually at low revs any idea what it could be ? I was told it may be my coil pack thats on the way out ? And will it fails its MOT with this ?
Thanks Callum
Nimminz
PostPosted: Fri Aug 26, 2011 5:04 am Up
We have the same problem only it cuts out after loosing power.
Engine management light come on?
I'm thinking its the coil pack.
Not sure on the MOT front though
2.0 8v RWD
Callum206
PostPosted: Fri Aug 26, 2011 5:06 am Up
Noo engine management light hasnt come on thats why i have no idea what it is ?
PostPosted: Fri Aug 26, 2011 5:45 am Up
The only way I can see a car failing it's MOT with a 'spluttering' engine is if it affects the emissions.
smiddies
PostPosted: Fri Aug 26, 2011 6:06 am Up
Even though the EML isnt on, there may be codes stored, Ive got a basic code reader that may do the job!
I know my cars spluttering atm, suspected to be coilpack!
PostPosted: Fri Aug 26, 2011 7:09 am Up
I thought you replaced the coilpack Callum?
Callum206
PostPosted: Fri Aug 26, 2011 7:21 am Up
I have a new one havent replaced it yet want to make sure before i go replacing it it is that.
Nimminz
PostPosted: Fri Aug 26, 2011 10:17 am Up
Hmm... Maybe i was wrong, the pug just blew her head gasket today lol probably the problems we were having had something to do with it leaking a bit, oil press. loss or something. or possibly coil packs out too and it was all just a not so happy coincidence
doubt your's will be the same
2.0 8v RWD
