Latest: heikkisj
Overall: 17126
Online Now [371]:
Visitors: 370
Today: 24371
Total: 100357329
Forums › The Car › 206 Problems › Passenger airbag cover
JackWrexham
PostPosted: Fri Aug 26, 2011 4:07 pm Up
Hello,
First post and one that I've been dying to know the answer to for a while,
I do not have a passenger airbag and don't really want one, the only thing I want to do is change the cover from a grey one to a black one, I can get a black one from the scrapyard but I don't have a clue how to get them off.
I want it as it will then match my doorcards and continue the stripe right through,
Any help would be much appreciated,
jackscottphotography.co.uk
pug206lx
PostPosted: Fri Aug 26, 2011 6:05 pm Up
Id take the glove box out and have a look up from behind to see if there's any obvious nuts and bolts.
D4NTP
PostPosted: Sat Aug 27, 2011 2:01 am Up
there are a couple of bolts at the back of the glove box and half a dozen screws. However the cover is riveted over the top of the airbag so you would have to drill it out and screw a 'new' cover on.
PostPosted: Sat Aug 27, 2011 2:05 am Up
He don't have a passenger airbag so its just a cover Razz
Removed my one other week, loads of little screws and hard to see with dash in but can still be got at.
PostPosted: Sat Aug 27, 2011 2:09 am Up
1/4" socket set & a good torch make the job slightly easier Laughing
Could always remove the passenger seat to help with access / helps save on a bad back as you lay in the footwell Wink
