Latest: SA01
Overall: 17138
Online Now [263]:
Visitors: 262
Today: 49286
Total: 112273644
Forums › The Car › 206 Problems › Jerking and Black Smoke 1.6hdi
2jof
PostPosted: Fri Aug 26, 2011 10:43 am Up
Every now and then my car, at low revs around 1500-2000, jerks when I gently accelerate and when it does this a puff of black smoke comes out of the exhaust. Could anybody shed some light on what this may be? feels like the turbo or something is going wrong, blocked pipe maybe?
Help would be appreciated,
206 1.6hdi GTI
PostPosted: Fri Aug 26, 2011 10:50 am Up
yes, 9 out of 10 is death turbo or boost leak
Harty
normally white smoke is a bad sign, black smoke is a trait of every diesel, maybe needing a fap regen? maybe a service?
Harty
Antknee
do you give it a good blast on the motorway now and again? usually helps with getting rid of soot build-ups in the DPF
2jof
PostPosted: Sun Aug 28, 2011 9:08 am Up
Fap has been removed so not that. this is why I am more inclined to go with the boost leak.
206 1.6hdi GTI
Lecktorious
PostPosted: Sun Aug 28, 2011 9:12 am Up
Trade Rating: +59
It won't, revs must be kept as low and steady as possible to allow regeneration, 50-60 MPH ideally. Whoring it up and down the motorway will only block up the filter more.
'98 Nile Blue 306 GTi 6
PostPosted: Sun Aug 28, 2011 9:40 am Up
it is easy to heard a boost leak.
