Online Now [332]:
Visitors: 331
Today: 162148
Total: 156876710
Forums › The Car › 206 Problems › Lil P broke down :(
Lil P broke down :(
xXx_LIL_P_xXx
PostPosted: Sun Aug 28, 2011 11:34 am Up
hiya well today has been eventful!
got upto asda turned in and i said to the other half i can smell petrol. didnt think anything of it.
i got out the car to go and get something looked back and the bf is saying i have got to come back and push her n she had stalled herself!
so got her round the corner and poped the bonet (fuel p**sing everywhere) the bf noticed the main fuel injector has poped off p**sing fuel all over the engine, starving the engine of fuel.
the bf tried poping it back on but it wouldnt stay Sad so yeah lil p is now still up in asda car park with a note in it saying broken down Sad
HELP! x
Black 206 1.1 V reg (00), 15" Sirocco Alloy Wheels, Colour Coded Sports Bumpers with Fog Lights, Standard Spoiler, Bosch Aerotwins, Phase 2 Rear Lights, Crystal Head Lights, SP Wheel Arches, GTi Fuel Cap, GTi Half Leather Interior, Official 206 GTi Kickplates, GTi Vent Sliders, Phase 2 Boot Handle (with key hole)
macj
PostPosted: Sun Aug 28, 2011 11:38 am Up
Thats bad..... the injectors are held in by the fuel rail.... something dont seem right here
my1st206
PostPosted: Sun Aug 28, 2011 12:03 pm Up
I had this issue and it was a small plastic clip that holds the fuel pipe onto the fuel rail, the aa guy bodged it with two cable ties and PUG told me I had to buy completley new fuel pip for about £80 in order to get a new plastic clip.
2003 1.1 Look
craigy00craig
PostPosted: Sun Aug 28, 2011 12:18 pm Up
This happened to me but the clip was just not put on properley so managed to get it back on. Not fun having a petrol leak on the motorway though!!!
Progress Threads:
Harty
PostPosted: Sun Aug 28, 2011 12:19 pm Up
is the clip removeable? scrappy job?
Harty
PostPosted: Sun Aug 28, 2011 12:21 pm Up
why you didn't tow it??,or get it fixed on the spot??
xXx_LIL_P_xXx
PostPosted: Sun Aug 28, 2011 1:00 pm Up
i didnt have my phone and the bfs had died Sad i do have aa cover though! going back tomorrow to see what we can do! x
craigy00craig
PostPosted: Sun Aug 28, 2011 1:12 pm Up
Hopefully should be too much of a problem, let us know how you get on!
Progress Threads:
xXx_LIL_P_xXx
PostPosted: Sun Aug 28, 2011 1:21 pm Up
shall do Very Happy lil p is looking more and more to be moved on Sad she is costing me to much! x
craigy00craig
PostPosted: Sun Aug 28, 2011 1:24 pm Up
thats all part of the fun of owning a french car Smile would be boring otherwise!
Progress Threads:
scotty206
PostPosted: Sun Aug 28, 2011 1:32 pm Up
same thing happened to me on the outside lane of the m6. got towed and had a new fuel rail installed. seems to be a common problem
PostPosted: Sun Aug 28, 2011 1:36 pm Up
aww..I understand,well glad you have the AA cover,that will be good,do your best to sort this out tomorrow,other wise don't leave it there alone by itself :(..poor Lil P Wink
pug206lx
PostPosted: Sun Aug 28, 2011 3:52 pm Up
Breather pipe off, Coil pack off, small metal plate between throttle body and cylinder head off, remove throttle cable, press the valve on the end of the fuel rail to relieve any pressure (careful), undo the two bolts holding the fuel rail on, either remove the rail and push all the injectors back in or try to push the injector back in tight by wiggling it and make sure the clips are secure, refit in order of removal. Double check it every now and then to make sure it hasn't started leaking (just to be sure)
If the fuel rail is broken id get one from a scrappy
I've done this 4 or 5 times on these engines needing injectors changed.
If you're not confident then get someone who is to do it. Its relatively straight forward.
craigy00craig
PostPosted: Sun Aug 28, 2011 3:59 pm Up
Progress Threads:
xXx_LIL_P_xXx
PostPosted: Mon Aug 29, 2011 7:57 am Up
or outside of asda Sad not good! was lucky where she broke dowm! on a slight downhill into asda! x
