Online Now [644]:
Visitors: 642
Bots: 2
Today: 107665
Total: 157413311
Forums › The Car › 206 Problems › Let's clear this one up....Shaky Idle in Peugeot's? SOLVED
panzer360gti
PostPosted: Mon Aug 29, 2011 3:45 am Up
So, after having the car for 5 months and doing a lot of head scratching, it finally sits at traffic lights and other places completely still! Well, pretty much...in fact I even sometimes think its stalled the engine is that calm and quiet...
The solution....
A smaller CAT, and a more aligned tight to the body exhaust!
Lambda sensor replaced (CAT and sensor courtesy of Lee!)
The idle stall problem has buggered off aswell, and I reckon thats down to the tightened up air intake, cleaned intake and coolant flush, making the engine run cooler (used to stall at 93oC thereabouts)
All I have to do now is wait and see what happens next for me to attempt to fix!
Peugeot 206 GTI 137 2.0
Deckchair5
PostPosted: Mon Aug 29, 2011 5:05 am Up
Well, it takes a lot of things to be running just right to get a nice steady idle speed. People have pointed to some of the more common problems but a lambda sensor or MAP sensor or the ETS can really ruin any chance of an even tickover. Besides normal service items of plugs and air filter then a simple exhaust leak will mean the lambda sensor gets all the wrong information. With so many variables then you could throw money at it like you're doing and try this or try that but by far the quickest and probably cheapest would be to have someone scan the sensors on running data at tickover and have someone who knows what they're looking for interpret the results
PostPosted: Mon Aug 29, 2011 5:07 am Up
what plug are you using?
Seb
PostPosted: Mon Aug 29, 2011 6:14 am Up
Staff - Seb
Mine shakes a little on idle but that's normal.
panzer360gti
PostPosted: Mon Aug 29, 2011 9:31 am Up
I'm using Bosch, new set of 4, and I'm not talking about idle speed, I mean the shaking from being on idle, I cured the erratic idle in other ways.
Seb
PostPosted: Mon Aug 29, 2011 9:40 am Up
Staff - Seb
Mine is idling dead fine but still shakes. Never managed to get rid of it.
panzer360gti
PostPosted: Mon Nov 14, 2011 1:22 pm Up
As above, solved!
