Online Now [615]:
Visitors: 614
Today: 107089
Total: 157412737
Forums › The Car › 206 Problems › Water noise from glove box area
allison99
PostPosted: Mon Aug 29, 2011 3:36 pm Up
Hi Everyone
Please could someone shine some light on this annoying problem my car has! There is water trapped somewhere in or around the glove box.It doesnt make a noise all the time but sounds like its moving from one place then seeps back over time.Its just like a bottle of water has been left in the car and is rolling around.The garage has tried all the things suggested on here,heater matrix,air locks,cleared out drain holes etc.Also they removed the glove box and the lining under the wheel arch.NOTHING. Where is this water? The mats are not wet and it is not getting any worse.I own a quiksilver 52plate 1.4 3dr. Any suggestions? Confused
Antknee
PostPosted: Mon Aug 29, 2011 3:46 pm Up
bottle of coke in't glovebox?
Matt
PostPosted: Tue Aug 30, 2011 12:52 am Up
Trade Rating: +32
My thoughts would lead me straight to the headgasket.
But as you took it to a garage I presume that they would have checked for this.
qwert
PostPosted: Tue Aug 30, 2011 1:47 am Up
Servo
brum brum
Ash
PostPosted: Tue Aug 30, 2011 2:46 am Up
Check the drainage holes in the passenger door too.
allison99
PostPosted: Thu Sep 01, 2011 2:41 pm Up
Thanks for all your ideas.Sort of ignored the noise this week! Feel like drilling a few holes in the dash!! Wall Bang
thanks
kevbeans
PostPosted: Thu Sep 01, 2011 2:42 pm Up
Easy fix for all interior rattles and noises... turn up the stereo. Works for me.
new to the whole peugeot thing!
jamesmcuk
PostPosted: Thu Sep 01, 2011 2:57 pm Up
Yes this is the first thing I would check too
allison99
PostPosted: Fri Sep 30, 2011 3:12 pm Up
More news on noise!!
Decided it is most likely huge airlock in heater matrix.But was then told the air is probably coming in through head gasket!!! Next idea is to drain the whole system and start again and see how quickly it develops.Is there anyway of checking head gasket? Or would you leave it alone for now? The car is not losing water and the oil is fine.
s35will
PostPosted: Tue Nov 08, 2011 1:12 pm Up
I had this noise for about 3 months and ignored it...head gasket went today. I thought it was nothing, I wish i had looked it up before.
2002 Peugeot 1.4 Look
PostPosted: Tue Nov 08, 2011 1:24 pm Up
Checked your water level?
Bled the system?
Do basics, then get back to us
JR1981
PostPosted: Thu Nov 10, 2011 3:03 pm Up
I have noticed the same thing on mine in the same place and i do have the exact same car Quiksilver, 52 plate. Sometimes it's there and sometimes it isnt. It sounds like a fair amount of water wherever it is. If you have any joy in finding out what it is please share.
erm yes i will update this later
greenpug2222
PostPosted: Mon Nov 14, 2011 11:51 am Up
I have this too,
It seems to only make the water noise upon acceleration. Even in neutral for a good while, whilst it warms up.......... then after it seems to get less and less.
why wont you work??????????????????? ARGH F**k it!!!!!
DavidPCoates
PostPosted: Mon Nov 14, 2011 12:26 pm Up
Hate to say it but we had this noise, later the car wouldnt start and it was headgasket gone, but it may just be low water or airlock in water system.
Dave
Dave Coates
djaydearz
PostPosted: Tue Nov 15, 2011 7:07 am Up
I had this, My turned out to be a radiator leak
Does your coolant go down quick by any chance?
