Latest: Beduff1977
Overall: 17134
Online Now [401]:
Visitors: 400
Today: 224289
Total: 107625821
Forums › The Car › 206 Problems › Screen washer says no
lenbt
PostPosted: Wed Aug 31, 2011 10:29 am Up
I've searched but I cant find the answer.
Do both front and back washers work from the same pump?
My back washer jet works but the front one doesnt, and it doesn't make any noise while trying to use it.
Has anyone else had this problem?
PostPosted: Wed Aug 31, 2011 10:30 am Up
Checked the fuse?
PostPosted: Wed Aug 31, 2011 10:35 am Up
Separate motors.
PostPosted: Wed Aug 31, 2011 10:42 am Up
They work of the same pump actually....
Fuse more than likely
PostPosted: Wed Aug 31, 2011 12:30 pm Up
How's it do that then?
lenbt
PostPosted: Wed Aug 31, 2011 1:49 pm Up
oh ok.
is there a fuse just for the pump or does it share one with any other functions?
If it just uses 1 pump as some other Peugeot's do then it wont be the fuse because the rear washer is working.
lenbt
PostPosted: Wed Aug 31, 2011 1:51 pm Up
oh and its pre-plexed if that makes any difference.
thank for the help
abs06
PostPosted: Wed Aug 31, 2011 6:36 pm Up
Uses one pump because it has two outlets.
I have 2 pumps spare (working) if u need. Pm me
The fuse is fkr the pump and does front and rear. More than likely your pump is blocked or knackered
Abs
Peugeot 206 1.6 Sport (55)
Audi A1 2.0 TDi Sport (14)
Deckchair5
PostPosted: Thu Sep 01, 2011 2:21 am Up
My back washer jet works but the front one doesn't, and it doesn't make any noise while trying to use it.
As it doesn't make any noise when selected but the pump works ok on rear then it sounds more like an electrical problem. See if the pump is getting power when front washers are selected.
PostPosted: Thu Sep 01, 2011 3:17 am Up
E5GDM wrote:
Separate motors.
Not on a 206 they dont Wink
neil35
PostPosted: Sun Sep 04, 2011 10:54 am Up
Unblock the jets on the bonnet with a pin Very Happy if not you may have noticed a puddle on the floor when trying the front washer,, split tube or fell off??
Edit: if no noise at all new pump i think about £13 new Very Happy
