Latest: flipflap
Overall: 17140
Online Now [157]:
Visitors: 156
Today: 49687
Total: 113705279
Forums › The Car › 206 Problems › ECU / BSI Repair
ECU / BSI Repair
jamesmcuk
PostPosted: Thu Sep 01, 2011 3:50 pm Up
Hi Guys
I have a 206 1.4 HDI 2002 and from buying it, it always had a glitch where it would jolt while travelling. The way you could replicate this yourself would be to literally turn the key off then on again quickly and thats how it felt. Anyway this got worse when one day it wouldn't start. There was a light ticking sound in the ignition position which I discovered was the fuel solenoid clicking in and out, and when this eventually stopped the car would start fine. Anyway long story short I bought some donor ECU kit and fitted it and the original probs went away.
Now though the car will start and drive but the temp needle is always in the red and STOP Flashes. Due to this it starts holding the revs back and has very low power quite soon after moving off.
So I swapped my old ecu back just to make sure there was no wiring fault on the temp sensor and sure enough it was fine. So it seems I now have two sets of ECU Kit with different probs but at least I can still drive with this set.
Anyway I want to repair my original set but having phoned BBA Reman they said they didn't do this ECU (Bosch). The guy sounded clueless so my question is two things
Are there any other reputable ones, after all its not hard for a cowboy to simply phone and say oh yeah its beyond repair and I can supply a new / recon one?
And is the guy at BBA talking out his ass?
thanks in advance
James
fps_cod
PostPosted: Thu Sep 01, 2011 3:53 pm Up
Can't help much, but i just sent my A3's Bosch ECU off to BBA to be fixed. So i'd say they can fix Bosch ones!
206 1.1 Lx- Sold
Audi A3 1.9TDI
White alloys
Limo Tints
Remaped
jamesmcuk
PostPosted: Thu Sep 01, 2011 3:54 pm Up
How much did they charge you mate?
fps_cod
PostPosted: Thu Sep 01, 2011 3:56 pm Up
Cost around £150 in total. Started off at £100, then the VAT and for them to pick it up and deliver it.
206 1.1 Lx- Sold
Audi A3 1.9TDI
White alloys
Limo Tints
Remaped
jamesmcuk
PostPosted: Thu Sep 01, 2011 3:57 pm Up
ah not to bad then - thanks
glenpring
PostPosted: Fri Sep 02, 2011 2:44 am Up
i need to send my ecu off to them just phoned them and gave them my Bosch ecu and they said they can do it. £50+vat to test and if there is a fault and they can fix it they said it will be 300+vat and thats for my 307 1.4 hdi
PostPosted: Fri Sep 02, 2011 2:48 am Up
ECU is nearly £900 new from Peugeot.
Just use the Bosch 10 digit ID number on the unit to find a replacment if it is faulty Wink
glenpring
PostPosted: Fri Sep 02, 2011 3:40 am Up
what would i need to change to get a second hand ecu working in my car???
PostPosted: Fri Sep 02, 2011 3:43 am Up
It would need unlocking / coding to the BSI unit.
glenpring
PostPosted: Fri Sep 02, 2011 3:57 am Up
where is the bsi unit??? i thought the ecu and bsi was the same thing??
PostPosted: Fri Sep 02, 2011 4:02 am Up
BSI unit is the body computer inside the car which is in complete overall charge.
ECU is just the engines brain which is under the bonnet.
glenpring
PostPosted: Fri Sep 02, 2011 4:21 am Up
o right so i need to find out if its the bis or ecu thats got a fault them? any i dear how ill find out what one is in control of the rad fan (i have no relays)
jamesmcuk
PostPosted: Fri Sep 02, 2011 11:29 am Up
there are quite a few relays in the BSI unit. I think the ECU tells the BSI to turn on the rad fan mate but could be worng. It happens a lot lol Laughing
@ MrBSI do you know anywhere reputable to get ECU's from?
PostPosted: Fri Sep 02, 2011 3:28 pm Up
Any Peugeot / Citroen main dealer.
OR
Go see your Bosch automotive dealer, you have the ecu & the 10 digit Bosch ID number will be on the sticker, doesnt get much easier then that to match it up.
jamesmcuk
PostPosted: Sat Sep 03, 2011 4:01 am Up
OR
I said reputable LOL
