Latest: kemppu
Overall: 17142
Online Now [54]:
Visitors: 53
Today: 7450
Total: 114046790
Forums › The Car › 206 Problems › Fitting a spoiler help please
austin316
PostPosted: Fri Sep 02, 2011 1:56 pm Up
Hi all, is there anyone around the west sussex area that would be willing to fit my spoiler via bolts only (i got the bolts etc). I just dont trust myself with a drill near my car haha. Will sort ya out foor doing so, thanks in advance Smile
5 door
1.1 8v
04 reg
Swordfish
PostPosted: Sat Sep 03, 2011 7:12 am Up
why not glue it onto your roof with some Bison Polymax? I did that a short time ago and it sits like a rock.
Black 206 1.6 16V
austin316
PostPosted: Sat Sep 03, 2011 1:12 pm Up
Would use glue, but atm im thinking of going a blue/black scheme, gloss black side strips, gloss black alloys and black spoiler. Reason i want it bolted is because when i come to sell the car possibly spray it blue (colour of the car).
5 door
1.1 8v
04 reg
PostPosted: Sat Sep 03, 2011 1:30 pm Up
Just use tigerseal it's more than strong enough to hold it. If you are going to spray it you can get it off and respray it anyway. Bolting is making it more difficult than it has to be in my opinion.
austin316
PostPosted: Sun Sep 04, 2011 11:38 am Up
How do you get tiger seal off? I heard it was pretty hard to get off?
5 door
1.1 8v
04 reg
-Dave-
PostPosted: Sun Sep 04, 2011 4:55 pm Up
Trade Rating: +36
The hardest part about bolting it on is where to drill the holes making sure it is lined up properly. I wouldn't worry to much about drilling the boot just make sure the holes are in the right place by using a piece of card with a metal pin though it. Place it on the spoiler then line it up on the boot using it to score the position of where you need to drill. Then from the outside use a small pilot drill bit to push throw so that when you drill from the inside you can see where to go. Inside the boot move the plastic covers in the corner to the side and drill though. Size up drill bits before you start with the bolts to ensure you don't drill the holes bigger than the bolts. The hardest part is lining it up before you start drilling cause once you start with the drill even if you are only slightly off it would cause countless problems. As said above I would also suggest using tiger seal as well as the bolts to ensure max grip but if you want to possibly take it off later I wouldn't bother. I believe I still have the pictures on my home pc of the last one I did so will check and stick up a how to if I still have them.
Ex 206 Owner.
S222Chan
PostPosted: Sun Sep 04, 2011 5:21 pm Up
I think you just get a sharp knife or blade against the seal and cut it, then probably some tar remover to get rid of the residue.
Tigerseal ftw Very Happy
