Latest: Willy.Sea
Overall: 17168
Online Now [57]:
Visitors: 56
Today: 39994
Total: 128587980
Forums › The Car › 206 Talk › Rear wiper disable?
Rear wiper disable?
abs06
PostPosted: Sun Sep 04, 2011 3:53 am Up
Basically can I disable the rear wiper...
I am gettin a bike carrier and I don't want the rear wiper to turn on when front is on and u go into reserve.
Can I just pull the fuse out. Is the rear wiper on separate fuse. Or maybe a switch in the boot…
Don't want to spend loads
Thank you in advance
Abs
Peugeot 206 1.6 Sport (55)
Audi A1 2.0 TDi Sport (14)
PostPosted: Sun Sep 04, 2011 4:02 am Up
pull the plastic cover off the inside of the boot lid and just disconnect it?? easy
PostPosted: Sun Sep 04, 2011 4:07 am Up
IIRC you can get it disabled in the BSI configuration using PP2000.
As Jord says, just disconnect the motor loom inside the tailgate, or remove the wiper arm
PostPosted: Sun Sep 04, 2011 4:13 am Up
You would be correct, I had mine enabled using this method
abs06
PostPosted: Sun Sep 04, 2011 5:00 am Up
I still want it working.
And still want that feature of turning on when in reverses. Jay temporally turn of while I got bike rack on. Maybe taking the arm off
How about adding a switch to the loom... Like maybe the power cable. Would I nee a relay?
Abs
abs06
PostPosted: Sun Sep 04, 2011 5:04 am Up
Abs
PostPosted: Sun Sep 04, 2011 5:35 am Up
Just put a switch in a convinent position in the boot & tap into the live wire leading to the wiper motor. You won't need a relay either.
Deckchair5
PostPosted: Sun Sep 04, 2011 6:16 am Up
I just pull the wiper up vertical to the rear screen whenever I use a rear bike carrier then it can rotate harmlessly in midair if I forget and start reversing with the front wipers on
Or you put a switch to your brain which says "I will not reverse with front wipers on" That's easier than you might think Very Happy
PostPosted: Sun Sep 04, 2011 2:14 pm Up
Or disconnect the reversing switch on the gearbox, or just don't reverse Laughing
