Online Now [54]:
Visitors: 53
Today: 61275
Total: 116797376
Forums › The Car › 206 Problems › Found the problem with the air con :(
jamesderby
PostPosted: Sun Sep 04, 2011 8:10 am Up
Well as i thought it wasn't just a simple re-gas that was needed. There is a leak on one of the joints on the tubing by the Driver's wheel arch. Peugeot wanted £200 for a set of tubing so i managed to get another set off ebay for £40 so i'm going to have a go at fitting them tomorrow and see if that sorts the problem. I'll let you know how it goes.
Soon to be a 206 owner
myke
PostPosted: Sun Sep 04, 2011 9:09 am Up
Good luck, hope it sorts the problem. Smile
jimjam19927
PostPosted: Sun Sep 04, 2011 11:44 am Up
If there was a leak would a bit of tape not done the job? £40 seems excessive for something you could easily patch up without seeing?
Member: 685
I Over Use Smilies Razz
Deckchair5
PostPosted: Sun Sep 04, 2011 12:38 pm Up
Air con high pressure side can easily reach 200psi. I don't think a piece of tape is going to do the job Very Happy
jamesderby
PostPosted: Mon Sep 05, 2011 3:37 am Up
Just had the pipes swapped over. And it all works great now. Air con guy said the compressor isn't as good as it should be but the car is 11 and the air is still ice cold so I'm not complaining, and it only cost me £65.
