Online Now [1060]:
Visitors: 1059
Today: 34830
Total: 155335551
Forums › The Car › 206 Problems › limp mode ?
limp mode ?
pug150
PostPosted: Mon Sep 05, 2011 5:01 am Up
looking at a cheap gti180 and in the add it says the ecu has crashed and put the car in limp mode!
is there anyway to reset the ecu so it'll rev up again?? i ask because on my type r scooby if i disconect the battery it resets the ecu so just wondered if it was the same principle.
tim30485
PostPosted: Mon Sep 05, 2011 6:22 am Up
think it needs a fault read? message lee....
Drive Smarter Not Faster!
almir92
PostPosted: Mon Sep 05, 2011 7:05 am Up
isnt there like a button under the bonnet behind the battery?
Deckchair5
PostPosted: Mon Sep 05, 2011 8:36 am Up
ECU goes into limp mode to protect the engine as it can't reliably work out what's happening from the engine sensors ie they don't make sense or add up so it restricts max rpm and throttle response
The impact sensor inertia cut off switch and its reset button under the bonnet is a g force cut off to fuel and sometimes ignition. Engine won't be allowed to start at all with that triggered
So you need to find out what the ECU is unhappy about - first stop- any fault codes stored-and fix that
PostPosted: Mon Sep 05, 2011 9:18 am Up
GTI 180 like all multiplexed 206's doesnt have a fuel inertia cut of switch under the bonnet as the airbag ecu controls this function Wink
Deckchair5
PostPosted: Mon Sep 05, 2011 12:09 pm Up
Thank you Surprised
pug150
PostPosted: Mon Sep 05, 2011 12:22 pm Up
Cheers for the replys ill give it a miss.
PostPosted: Mon Sep 05, 2011 12:39 pm Up
GTI 180 is EOBD compatible, scanning it for fault codes to see why the engine managment light is on & why its stuck in limp mode is easy / cheap enough Wink
pug150
PostPosted: Mon Sep 05, 2011 1:35 pm Up
Yeah cheap enough to fibd out the problem but thats when itll get expensive and turn out to be a pain, plenty more forsale Wink
