Online Now [1058]:
Visitors: 1058
Today: 462757
Total: 153857234
Forums › The Car › 206 Problems › Speedo repair
Speedo repair
d87heaven
PostPosted: Wed Sep 07, 2011 11:44 am Up
Anybody ever dismantled the cluster and replaced the motor that drives the speedo needle?
206gti
kieron
PostPosted: Wed Sep 07, 2011 12:46 pm Up
Yes i have, belive it or not the speedo and rev couner use the same motor.
what would you like to know?
Account suspended
d87heaven
PostPosted: Wed Sep 07, 2011 1:47 pm Up
Easy enough to do? Any idea of what the part is or if its available?
Could possibly be this ...... speedo repair
cheers
206gti
kieron
PostPosted: Wed Sep 07, 2011 2:08 pm Up
Yes quite easy, the clocks will split into 3 sections and you need to remove the needles using a fork and pushing them off
that is the part you need but only the case you need the compleat motor, all its got is 2 clips that hold it in and then 4 pins that go onto the board to make the connection
you could buy any speedo from the 206 range and switch the motor over
www.akspeedo.com/peuge...motors.php
Account suspended
d87heaven
PostPosted: Wed Sep 07, 2011 11:49 pm Up
Excellent. Thanks for the info.
206gti
rick-gti
PostPosted: Thu Sep 08, 2011 1:35 am Up
i have a similar problem but it is my rev counter thats not working. would this be the same fix?
clio 197sport owner
kieron
PostPosted: Thu Sep 08, 2011 1:53 am Up
could be, swap it over and see if it works?
Account suspended
MPorter13
PostPosted: Tue Jul 03, 2012 3:05 pm Up
how could i replace the mileage board? i think thats what its called anyway.
any ideas?
MPorter
PostPosted: Thu Aug 23, 2012 4:02 pm Up
'I got here by searching' Shocked
My temp gauge shows exactly 10 degrees C colder than checked by PP2000 and have already tried changing ECT sensor. So 98 C is shown as 88 C which is totaly unacceptable.
1) Can I just pull the needle off and re-push it at the right place on the stepper spindle?
2) Why not?
