Latest: Andyblue64
Overall: 17123
Online Now [291]:
Visitors: 290
Today: 21986
Total: 98210278
Forums › The Car › 206 Problems › Gti 140 clocks
Gti 140 clocks
rick-gti
PostPosted: Sat Sep 10, 2011 1:12 am Up
Took the clocks out of my gti to fix my rev counter and while opening them up the ribbon from the mileage display came away. How does this attach to the circuit board?
clio 197sport owner
Lewis
PostPosted: Sat Sep 10, 2011 2:58 am Up
oh no...
Tivoli LX 1.1
Black GTI 180
White VXR Burg
meady
PostPosted: Sat Sep 10, 2011 6:55 am Up
Trade Rating: +45
By the sounds of tht reply it means new clocks
TEAM - I HATE FACEBOOK Smile
rick-gti
PostPosted: Sat Sep 10, 2011 1:46 pm Up
Has anyone got a set, gt or gti clocks. Also can the milage be set so its right?
clio 197sport owner
PostPosted: Sat Sep 10, 2011 3:54 pm Up
Multiplex or Pre-plex?
rick-gti
PostPosted: Sun Sep 11, 2011 1:07 am Up
Multiplex I think, got 2 plugs.
clio 197sport owner
rick-gti
PostPosted: Sun Sep 11, 2011 4:43 am Up
Another set of clocks is no good. Im unable to get the mileage corrected. All I have to do to mine is re-attach the ribbon that goes from the screen to the circuit board.
clio 197sport owner
PostPosted: Sun Sep 11, 2011 6:48 am Up
Why can you not swap the clocks?
rick-gti
PostPosted: Sun Sep 11, 2011 7:34 am Up
Dont really want to spend £40 on another set of clocks and the cost to get the milage corrected. I only need to refix the ribbon but not sure how its fixed, glued or soldered?
clio 197sport owner
Lewis
PostPosted: Sun Sep 11, 2011 8:07 am Up
Well what ever way it was connected you should solder it back on! Just make sure its all wired up correctly Smile
Cant imagine it will be easy!! Hence hwy most people usually just buy a set of new clocks if they break it!
If you get a set of clocks with lower mileage than your own they will automatically rise to your mileage
Tivoli LX 1.1
Black GTI 180
White VXR Burg
PostPosted: Sun Sep 11, 2011 8:11 am Up
If it is multiplexed you won't have to get the clocks changed, they are stored in the BSI and will change accordingly
A search would have helped you discover that Wink
PostPosted: Sun Sep 11, 2011 8:38 am Up
ONLY if the mileage on the replacement clocks is LOWER Wink
PostPosted: Sun Sep 11, 2011 8:44 am Up
I never said anything in detail Wink I ain't doing ALL the work.
rick-gti
PostPosted: Mon Sep 12, 2011 6:22 am Up
ive got a spare set of clocks so going to try and make 1 good out of the pair, and am keeping my eye open for another set with 80000 miles or less. most ive found have been higher.
clio 197sport owner
